Steering Rack Hack?
35 replies to this topic
#1 AlasdairM
AlasdairM
  • 240 posts
Posted 11 May 2021 - 08:20 PM
Hello
My 1992 cooper failed its MOT today, for excessive play in the steering rack (and a torn gaiter).
I immediately bought a new replacement rack from Minispares, and it's due to arrive tomorrow. Upon further reading though, the job looks like a bit of a nightmare! A good amount of work anyway.
My question is, is it worth trying this method: ???
I could then just replace the bushes, or at worst the steering rods (if they need done).
What are your thoughts?
I am also doing this on the street, hence why I am inclined to take the easier option...
#2 AlasdairM
AlasdairM
  • 240 posts
https://www.ebay.co....HAAAOSwG0dgeAnY
 this would be the replacement rod I would use...
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 May 2021 - 08:29 PM
You change the full rack, they usually come with rack ends and gaitors fitted.
Personally I'd renew the track rod ends whilst you have the old ones off.
I've changed racks with the engine in place in my garage, not fun! But it can be done!
#4 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 11 May 2021 - 08:34 PM
It's the bushes that fail the MOT.  You can replace the bushes in situ - some work is here
Edited by floormanager, 11 May 2021 - 08:36 PM.
#5 AlasdairM
AlasdairM
  • 240 posts
Posted 11 May 2021 - 08:40 PM
Thanks both.
Floormanager, is this the bush I would need to replace? https://www.minispar...px|Back to shop
I also have a spare gaitor, so could fix this when I am replacing that bush.
I would much rather keep the rack on the car, rather than dropping the subframe!
#6 floormanager
floormanager
  • 681 posts
Posted 12 May 2021 - 07:00 AM
Thanks both.
Yes, it is but Somerfords also sell the metal outer ring that goes round it, which you might need / be better to replace #7 on this picture.
Attached File  Capture.JPG   21.09K   11 downloads
I had a practice on an old rack, not too bad out of the car!!  Can send pics if you want.
Paul
#7 AlasdairM
AlasdairM
  • 240 posts
Posted 12 May 2021 - 07:27 AM
Thanks both.
Paul
Thank you.
Yes if you wouldn't mind sending some pics, that would be great!
IMO it's worth a shot. If there is still play after replacing the bushing, then i'll be back to replacing the whole rack anyway.
#8 nicklouse
  • 18,574 posts
Posted 12 May 2021 - 07:38 AM
I would still replace the rack.
#9 AlasdairM
AlasdairM
  • 240 posts
Posted 12 May 2021 - 08:24 AM
Yes I've ordered a new one, but I would rather save that for a winter job (when the mini is garaged).
This bush replacement should work for the MOT/summer (hopefully!)
#10 viz139
viz139
  • 665 posts
  • Local Club: Irish Mini Owners Club
Posted 12 May 2021 - 09:56 PM
The bush in the link above does 70's - 80's racks but is different to MPi racks and I do not know the change over year. I have done the bush out of the car and don't think I would try it in the car. In the video he doesn't show the unpeening and repeening of the collar that would be tricky in place. Note that the video is for a LHD car and there is only one bush on the passanger side. If your steering box is worn that is a different kettle of fish.
#11 Spider
  • 14,838 posts
Posted 13 May 2021 - 02:48 AM
I have made a tool to get the bush out while the rack is in the car. It’s fairly easy to fit the new one, however inevitably it will also need some adjusting too, so in your case here, perhaps a replacement would be the best way forward.
It’s not a hard job to get them out or to refit them. If you have a helper, you’d do the job in 2 - 3 hrs. One tip I’ll pass on here is the U bolts tend to spread, so test fit them from the inside of the car, you do want them an easy fit. If you need to close them up, fit some nuts on the threads and gentley squash them up in a vice or if you don’t have one, tap them with a hammer.
#12 Tornado99
Tornado99
  • 750 posts
Posted 13 May 2021 - 03:57 AM
I was preparing to have the rack replaced when a local min specialist shop (Steveston Motor Co) thought solution might just be to replace the steering column as the splines seemed worn, there was play at the spline clamp that could not be taken out with more bolt torque.
So did the column swap myself. Found the upper plastic bushings were absent and fitted new ones. New splines on column side of join seems to have complete solved the steering play. New upper bushing has made a much better steering feel at the wheel.
#13 AlasdairM
AlasdairM
  • 240 posts
Posted 13 May 2021 - 08:03 AM
ok thanks a lot all.
Maybe I'm just being a chicken in not replacing the whole lot.
I recently changed 4 shock absorbers on a B7 Audi RS4 (2007) on the street outside my flat, so if I can do that, I shouldn't be so worried about working on the mini!
I only have 2 axle stands and a trolley jack- hopefully this will be enough to get the job done.
#14 nicklouse
  • 18,574 posts
Posted 13 May 2021 - 08:32 AM
All you need. And some other odds and ends. Just take your time and drop the rear of the subframe a little further than you think you need.
#15 AlasdairM
AlasdairM
  • 240 posts
Posted 13 May 2021 - 08:41 AM
okey thanks. I just hope I don't burst and pipes or hoses in the meantime! I'll just take my time- it can't be that hard!
