Think Il try that at some point. Thank you.
Core Plugs
Elwyn
, May 10 2021 08:20 PM
16 replies to this topic
#16
Posted 12 May 2021 - 11:35 AM
#17
Posted 13 May 2021 - 12:16 PM
HI,
I did the engine flush with ascorbic acid. As far as it is a light acid, it can easiliy remove the rust then the sludge from the system, but do not harm the system. I bought 500 grams of it (white powder like consistant) in the pharmacy in Hungary because it is very good substitution for Vitamin C, and added it to the cooling system where the water is filled, and driven arround 100 kms. Than removed the thermostate and opened the system at the top heater hose and flushed the system gently 3 times. It worked perfectly for me. :)
