Hello
1993 L reg SPI Cooper, manual
I bought a Mini Spares valve spring compressor
Turns out it's by Sykes Pickavant
The instructions are for a slightly different compressor, referring to parts I don't have
This is what I have : TOOL05 - Mini valve spring compressor (minispares.com)
It should be simple
The open end (adjustable) around the top of the valve / top caps
The G clamp adjustable end against the corresponding valve
Tighten the G clamp alike thing
Spring compresses
Collets become accessible
Pop them off
Done
And repeat
However...
Using Tool05, with the G clamp alike thing at it's tightest, the valve springs either don't move at all or they move nowhere near enough to get at the collets
There's plenty of thread on the G clamp alike thing, but not where I need them
Presumably fine for a deeper cylinder head
But I bought it for a mini from Mini Spares, so you'd think it would be right?
And having only tackled one, with Tool05 fresh out of the packet, the winding lever (small and feeble) is already significantly bent
What am I doing wrong?
As always, I tried swearing first
And second
Then this
Thanks in advance
Elwyn
