Posted 06 May 2021 - 06:56 PM
My 1991 Mini cooper 1275 hif44 has the following problem:
Sometimes the engine needs 5 or 6 turns before it catches on. Other times it will start after only one turn. The car is completely standard.
What already has been replaced during the restoration:
Ignition
Coil with gcl143
Spark plugs and wires
Fuel pump
Carb has been rebuild
Compression is exactly what it should be, the engine starts fine when warm.
Did I miss something, or what else could it be?
Posted 06 May 2021 - 07:04 PM
Remember if it's from a totally cold start that the fuel pump will need time to lift fuel from the tank (assuming mechanical pump)
Another possibility is the choke cable isn't set quite how it was before the rebuild.
Regards
Cal
Edited by cal844, 06 May 2021 - 07:06 PM.
Posted 07 May 2021 - 12:29 AM
What plug gap are you running? You could try increasing it a little.
Posted 07 May 2021 - 07:45 AM
Posted 07 May 2021 - 09:15 AM
Posted 07 May 2021 - 11:10 AM
Posted 07 May 2021 - 12:23 PM
Things I would consider are as follows-
Is the fuel fresh?, I have just had another tank go off whilst the Mini was being used infrequently.
The bad fuel meant it was hard to start from cold, but did run once warmed up.
Is the battery in good health and the starter motor?, sometimes you can find the starter is taking too much power to crank and the ignition system is left under powered.
You can sometimes tell this if the engine catches when you release the key from the cranking position and the engine fires whilst still spinning over from the starter
Posted 07 May 2021 - 03:46 PM
What fuel are you on over there in the Netherlands ?
By this I mean are you on E10 yet which is added in the fuel (Ethanol) ? (Awful gear)
It is due to hit the forecourts soon at Petrol stations, but wondered if you are already using it in your fuels. I seem to think I read that your Government were keen to roll it out quite quickly there and be using it by now.
One thing you could also look at is your timing, see if it is a little retarded, just ideas for the pot.
Posted 07 May 2021 - 05:36 PM
Check the flow and amount to the carb?
Posted 09 August 2022 - 08:59 AM
Hello,
It's been a year but the Mini still has the same problem. And I would like to solve it. It takes a while for it to start. And the idle fluctuates. New things I have tested:
Disconnected fuel pump and tried to start with exactly the same result the car starts after 5/6 turns and runs fine on the contents of carb. Which rules out the fuel pump.
New Plugs
Checked the ignition timing
Used high octane fuel
After a long drive the idle fluctuation becomes less. When driving It runs perfect.
What else can I try?
Posted 09 August 2022 - 09:20 AM
Posted 09 August 2022 - 09:43 AM
When I adjust the carburator to be richer the idle gets better.
But it becomes to rich at higher RPM when driving. It also makes no difference for starting.
Edited by Nielsj1996, 09 August 2022 - 09:49 AM.
Posted 09 August 2022 - 11:18 AM
Always worth looking for vacuum leaks when messing about, believe they can play havoc with idle.
Temp disconnect vac from carb to dizzy (block carb end) quick and easy to try.
Posted 09 August 2022 - 01:39 PM
Edited by Nielsj1996, 09 August 2022 - 01:42 PM.
Posted 09 August 2022 - 05:40 PM
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
