Mountney Steering Wheel And Boss Kit Assembly
7 replies to this topic
#1 maka
maka
  • 20 posts
Posted 03 May 2021 - 10:04 AM
Hi guys,
I just got myself a new Mountney steering wheel and boss kit. I was wondering if you could help me with the assembly, the instructions are not very clear.
This is the first option (which I think is the correct one) but the problem here is that the horn push button is recessed, I would expect it to sit higher.
Attached File  849FEC12-7A59-403D-A0B5-FFC7870CB943.jpeg   57.7K   5 downloads
The second option without the finishing rim let the bolts be too apparent.
Attached File  3767D2AA-FFBE-43F1-B344-2E7978BBB38D.jpeg   52.94K   4 downloads
What do you guys think ?
Thanks.
Edited by maka, 03 May 2021 - 10:05 AM.
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 03 May 2021 - 11:21 AM
I like both ways to be honest. Sorry thats not helpful.
#3 maka
maka
  • 20 posts
Posted 03 May 2021 - 11:56 AM
So for you both ways are correct ?
#4 KTS
KTS
  • 2,421 posts
Posted 03 May 2021 - 12:26 PM
if you don't like the horn button being recessed when the finishing ring is fitted, you could try and fit a spacer below the horn button to bring it up level with the finishing rim
if you choose not to use the finishing ring; you could use a fastener that has a much lower profile on the head like Hi-Lok bolts to attach the steering wheel to the boss
alternatively, you could countersink the holes in the steering wheel, so the screws sit flush, and not fit the finishing ring
Edited by KTS, 03 May 2021 - 12:32 PM.
#5 Maccmike8
Maccmike8
  • 1,101 posts
Posted 03 May 2021 - 12:50 PM
Yeah. Mine is like image 2.
Image 1 has the countersinks so again is correct.
Think its your preference really.
As KTS says you couls space the horn button.
#6 maka
maka
  • 20 posts
Posted 03 May 2021 - 02:01 PM
Thank you, that’s a good idea will try that.
#7 Chris1275gt
Chris1275gt
  • 938 posts
Posted 03 May 2021 - 04:18 PM
Photo 2 looks best but the Phillips screw heads are to big so, have a look at these on eBay item no 233377779833 they are stainless steel with a low profile and have an Allen key head I used them on my mountney when I had one and they looked fine. The lip is not really noticeable when it's fitted and used.
Edited by Chris1275gt, 03 May 2021 - 04:21 PM.
#8 UHR850
UHR850
    Just On Tickover
  • 5 posts
Posted 21 June 2021 - 01:17 PM
Wthout the ring looks much better, you don't need the ring at all.
Kees.
