1966 Mini Van (The Rustiest One Yet?)
52 replies to this topic
#31 pete l
pete l
  • 1,368 posts
Posted 04 October 2021 - 09:10 AM
Wow
#32 Homersimpson
Homersimpson
  • 829 posts
Posted 04 October 2021 - 04:43 PM
Thats looking fantastic and the jig is a great idea as you have another one the same to do.
I remember looking at a jig for a frogeye sprite bodyshell and it had all kinds of removable bits for setting everything up which worked really well.
#33 fiestaharry
fiestaharry
  • 295 posts
Posted 11 October 2021 - 05:31 PM
Update:
Had a few days off the week just gone so put my time into prepping as much as i could ready to go back on the car.
Painted the inner and outer A panel with Mipa epoxy primer and got them spot welded:
Had some of the origional brackets / mounts to repair / bare metal:
Started spotwelding the floor to toeboard, toeboard to bulkhead and bulkhead to crossmember:
Primed the inaccessible void, inside all the sill sections and the underside of the load floor:
Fitted the spare wheel stabiliser:
Beach buggy anyone?
I next went onto sorting the brackets that hold the bonnet hinge onto the bulkhead, obviously this needs to be in the right place so:
Used the brackets from my woody to mock everything up and has worked well. I am going to be needing these again for the pickup.
More prep:
Bit the bullet and started on the sides, going really well upto now:
Pretty happy with the fit up of everything:
Got loads of welding to do now but going to be doing a few hours a night after work to get though it  :D
#34 sonscar
sonscar
  • 2,987 posts
Posted 11 October 2021 - 05:39 PM
Lovely work,thanks for sharing,Steve..
#35 cal844
cal844
  • 9,621 posts
  • Local Club: TFMOC
Posted 14 October 2021 - 03:29 PM
Wow! You're keen but then I suppose these cars are easy if you can weld and paint. Great work so far
#36 Homersimpson
Homersimpson
  • 829 posts
Posted 27 October 2021 - 10:43 PM
The car is looking great :-)
What do you use to paint the steering wheel?  I have one to do on a MK2 jag thats in a similar condition.
Edited by Homersimpson, 27 October 2021 - 10:44 PM.
#37 fiestaharry
fiestaharry
  • 295 posts
Posted 31 October 2021 - 11:48 AM
Just 2k direct gloss
#38 fiestaharry
fiestaharry
  • 295 posts
Posted 31 October 2021 - 11:49 AM
Update:
Been doing all of the difficult, boring jobs at the moment, the tricky top of the a pillar repair on both sides:
Another job, bottoms of both door frame repairs:
Done a load of welding on the front bulkhead area for wiring tabs, accelerator cable ferrules, threaded shock absorber mounts, threaded pedal box mounts, a panel stiffner, some threaded inserts etc.
But FINALLY after a huge amount of work (while working full time and only having a few days off) after 1 month after receiving the panels it is nearly ready for expoxy, i have to 180 grit sand everything (half way there) and do some more small detail welding bits:
#39 wingnut
wingnut
  • 463 posts
Posted 01 November 2021 - 06:09 PM
I can't believe this is the same van!
Truly inspiring
#40 fiestaharry
fiestaharry
  • 295 posts
Posted 07 November 2021 - 03:01 PM
Update, body now has epoxy primer on. More finishing touches to do on the booth, painting etc but extraction and air worked really well.
#41 Maccmike8
Maccmike8
  • 1,101 posts
Posted 07 November 2021 - 03:29 PM
Fantastic.
#42 mini-mad-mark
mini-mad-mark
  • 848 posts
  • Local Club: northants wot no brakes
Posted 07 November 2021 - 10:10 PM
Great work and in such a short timescale. I wish I had a welder, the skill, a large garage, the skill, the time, the skill, the money and the skill to do a rebuild like this.
#43 pete l
pete l
  • 1,368 posts
Posted 08 November 2021 - 10:28 AM
Can you tell us more about your paint booth please, i'll be setting one up soon but can't really decide how to do it !
Thanks.
#44 fiestaharry
fiestaharry
  • 295 posts
Posted 14 November 2021 - 04:11 PM
Thanks.
Sorry for the late reply, what do you want to know?
#45 g111mds
g111mds
  • 432 posts
Posted 14 November 2021 - 09:32 PM
Incredible work
