Cooper Spi On Std 12" Wheels - Which Tyre Is Recommended These Days?
5 replies to this topic
#1 northernboy
northernboy
  • 35 posts
Posted 01 May 2021 - 05:52 AM
I have the Original Rover 4.5 x 12" Minilites and need to get 5 new tyres - there is not a great choice in this size so was wondering what people tend to fit or recommend.
The car will be used for standard road use and I want to keep the 145 x 70 x 12 profile for originality.
I have found ( all fitted price)
  • Nankang Econex NA-1 (£52 each)  ( blackcircles)
  • Powertrac CityTour 70EC  (£31 each)   (merit tyres)
  • ​I also read about Falcon but can't find these fitted
thoughts ?
#2 mab01uk
mab01uk
  • 12,412 posts
Posted 01 May 2021 - 08:17 AM
Minispares now do the original Pirelli 12" Mini tyres used by Rover:-
145/70/12 PIRELLI CINTURATO TYRE
Genuine Pirelli 145/70/12 Cinturato tyre as fitted as standard to 12" wheel Minis in the 80's after testing was done by British Leyland and found these to be superior for allround road holding in wet and dry conditions, they also had a very good wear rate:-
http://www.minispare...px|Back to shop
Edited by mab01uk, 01 May 2021 - 08:20 AM.
#3 northernboy
northernboy
  • 35 posts
Posted 01 May 2021 - 08:16 PM
Many thanks - I will have a look at these - have always liked Pirelli
#4 brivinci
brivinci
  • 1,172 posts
Posted 03 May 2021 - 08:22 PM
I have run Falcons years ago. Story was that they actually have good grip in the dry but their wet performance was lacking. Currently running Yokohama A539's. I do not have any complaints. They are 165/60/12. Fit the stock wheel just fine.
#5 michelmk2
michelmk2
    Just On Tickover
  • 6 posts
Posted 14 May 2021 - 11:22 AM
I 'm vey happy with my Nankang for daily usage
#6 [email protected]
[email protected]
  • 127 posts
  • Local Club: Long Island Mini Enthusiasts
Posted 17 November 2021 - 05:24 AM
We get all 4 seasons in NYC, USA, and I cannot afford two sets of tires, so I have always run "summer snows". Not a full-on winter compound that simply disintegrates in summer heat, but rather an "all weather / all season" tire with the three peak & snowflake logo - essential if you get real snow like we do.
My first 5 years were on a set of four 145/70R12 69Q Hankook Winter Icept W605 (on the 4.5x12 Rover Minilites that it sounds like you have).
I could pass Jeeps in the snow with those, and they worked reasonably well in the dry and wet, I even ran a few laps around Watkins Glen when they were nearly worn down to slicks near the end of their life).
But they aren't available anymore, so I moved onto a set of four Nankang SV-2. I've had them for about 4 years and am still pretty happy with them. I even think they'll start cracking from age and being parked outside before the tread is all gone.
My next set of tires will likely be the Nankang SV-3 from Minispares http://www.minispare.../12/TYRE27.aspx because they've copied their new tread design from Michelin's Cross Climate 2. Watch this video about this new directional tread design trend https://youtu.be/PT2odY3C6Og
But see https://www.nankangt...ts/winter/sv-3/ for the new tread design - Note that the picture on the Minispares site is still the SV-2), so hopefully they will be even better than the SV-2 have been for me. And, honestly, simply because I can afford them.
Another, twice as expensive tire to consider is the Pirelli mentioned above - but only if it is their SF2 all season tire here: https://www.pirelli....all-season-sf-2 and here: https://youtu.be/A3WssIxusLU
Unfortunately I can't tell if it is the SF2 on the Minispares site: http://www.minispare...12/TYRE35.aspx, but it is more likely the CN54 as seen here: https://www.longston...urato-cn54.html
Which is fine if you want that "vintage vibe", but don't expect terrific all weather road holding with a tread design that dates back to 1972.
Yes, the rubber is more modern, but read more here:
https://press.pirell...rato-500eng.pdf and here:
https://www.cinturato.net/125-12.html
Hope this is helpful!
