Glueing Rear View Mirror
5 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 26 April 2021 - 07:05 AM
Hey guys,
Anyone had any luck with those double sided tape pads to glue their rear view mirror? What brand did you use? Bought a pad in a local store but the mirror quickly fell off ( hitting the gearstick and destroying the mirror-of the joy-).
#2 Ethel
  • 25,919 posts
Posted 26 April 2021 - 08:28 AM
Pad came of the mirror or the screen, not clean or dry enough?
The screen's curved so you'd need a certain amount of  thickness & give in the pad to get full contact.
#3 GraemeC
GraemeC
  • 7,438 posts
Posted 26 April 2021 - 09:16 AM
Not had a problem with them - make sure both surfaces are perfectly clean - wipe with thinners.  Then warm them with a hairdryer before applying the pad.
I tend to put the pad on the mirror and leave it for 24 hours to make sure that side has a good bond.  Then stick it to the screen.
Like anything - make sure it is a good quality one from a recognised manufacturer.  I think the ones over here are generally from Summit and use 3M adhesive. I think Loctite also do one.
Edited by GraemeC, 26 April 2021 - 09:17 AM.
#4 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 26 April 2021 - 09:24 AM
Never found double sided sticky pads unable to cope with the weight of a rear view mirror for very long so i switched to using Loctite 319 Rear View Mirror Bonder.
Never had a mirror fall off since i started using it.
#5 Dusky
Dusky
  • 5,322 posts
Posted 26 April 2021 - 10:09 AM
I’ll try warming the pad, cleaned everything with Berner brake cleaner before applying it.
Might try supporting the mirror somehow
#6 mab01uk
mab01uk
  • 12,412 posts
Posted 26 April 2021 - 10:51 AM
This Loctite 319 kit also worked well with a heavy interior mirror for me:-
https://www.halfords...kit-464404.html
Warm the glass with a hairdryer (or sunny day) and prop/support the mirror in place for a while, overnight if possible.
Edited by mab01uk, 26 April 2021 - 10:54 AM.
