Cooling system service
8 replies to this topic
#1 Neon
Neon
  • 308 posts
Posted 04 November 2006 - 05:34 PM
Got a new rad to put on next weekend, and while i'm at it i'll flush it through aswell. Any advice or things to be careful of whilst doing this?
Also I'm going to put a new thermostat in as its running rather cold at the minute. What temp should i get for a 1991 998?
#2 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 05:56 PM
Standard Thermo kit form halford will do the job. flush through once and then I filled with plain water, ran the car for 5 mins, then get rid of that and put water and coolant in.
#3 1984mini25
1984mini25
  • 8,783 posts
Posted 04 November 2006 - 06:08 PM
You want a 88oC on for a 998, be careful if you get one from Halfords and check the one in the box first, as the last time I was looking the part no they recommended to be an 88oC one turned out to be an 82oC one. Ended up getting a proper one from minispares for half the price.
And a 50% antifreeze to 50% water mix in the cooling system all year round.
You will also need about 3 ½ to 4 litres (depends upon how much you spill) of coolant to fill the system completely.
Edited by 1984mini25, 04 November 2006 - 06:09 PM.
#4 Pooky
Pooky
  • 5,691 posts
Posted 04 November 2006 - 06:17 PM
I think my mini runs a bit cold, the needle rarely goes over 1/4 up the gauge. Should I get a new stat? Which one woudl it have as standard and which should I get?
#5 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 06:18 PM
that's if you still running a 998 of course.
#6 Neon
Neon
  • 308 posts
Posted 04 November 2006 - 08:29 PM
Will I need 4 litres of coolant + 4 litres of water? Or is that value to fill the entire system?
#7 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 08:36 PM
No that'd be 8 litres, up to four litres of water and coolant mixed 50/50
#8 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 04 November 2006 - 08:47 PM
Whys that?
#9 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 05 November 2006 - 09:56 AM
I didn't quite make myself clear,..... i was asking if he still had a 998 or whether he was running a 1275.. lol, it wasn't really related to the thermostat thing lol. sorry guys. :D
