Valve Guides Reaming And Clearance
7 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 14 April 2021 - 09:30 PM
Need some advice on valve guides, reaming and clearance.
I'll be fitting cast iron valve guides and understand the ID is 9/32 or 7.14mm, is this before or after reaming?
If reaming (and I have found some info suggesting that cast iron guides don't get reamed), what size reamer do I need and where can I get one?
I understand from searching on here that the clearance should be 0.012"
Many thanks
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 14 April 2021 - 10:04 PM
Valve guides close up when inserted. The finished size is that produced by a 9/32” reamer. HSS reamers wear quickly, I have had much more success with a solid carbide reamer. MSC direct sell a budget solid carbide chucking reamer which is what I now use.
I used HSS reamers for years the trick to getting them to last is to modify them.
Ac
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 14 April 2021 - 10:25 PM
The guides always need reaming to provide clearance regardless of material type.
Phil.
#4 dotmatrix
dotmatrix
  • 439 posts
Posted 15 April 2021 - 08:38 AM
I bought an adjustable reamer that I use because when I change valve guides but not valves, the size differ a little bit from valve to valve especially in engines that have had e.g a burned valve changed, so the guides may not need to be the same diameter all of them.
I'm not sure its the correct practice but this is what I do
#5 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 15 April 2021 - 10:16 AM
Should only be doing a couple of heads, unless I am successful then I might start doing other peoples, nothing like a bit of competition 😉
I’ll look at the carbide ones from MSC but if they are Uber expensive, I’ll get a HSS one.
Thanks for the info.
#6 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 17 April 2021 - 08:28 AM
Found a 9/32 Hand Reamer here, although it does not specify the length of the tool so I have messaged the company.
I already have a T Bar which I bout for cleaning out threads.
Wonder if I could use this in a bench drill?
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 19 April 2021 - 01:35 PM
Had a reply from the company selling these.
Details are:
Overall Length: 108mm.
Cutting Length: 60mm.
Don’t have a head with me at the mo, but as a standard deck is 70mm, these reamers should be ok.
#8 Icey
Icey
  • 1,551 posts
Posted 19 April 2021 - 02:29 PM
I've used Arceuro to buy quite a bit of machine stuff. The cutters I've had from them have been good. I did chip an end mill but that was by being stupid rather than the tool.
