Austin Metro Hle 1984
108 replies to this topic
#31 longtimenomini
longtimenomini
  • 708 posts
Posted 22 April 2021 - 06:44 PM
Bung in the big bobbins on the b reg
Gear change refresh .....
#32 longtimenomini
longtimenomini
  • 708 posts
Posted 22 April 2021 - 07:32 PM
Right ... which led to needing to replace front linkage bush ...
#33 longtimenomini
longtimenomini
  • 708 posts
Posted 23 April 2021 - 05:29 PM
So , I do this to all my minis / metros . (Along with other tips/ tricks and design changes ... more to come) I use the longer mini moke KAD quickshift gear-lever . This brings the gear lever/ knob close to steering wheel ( a la touring car) it also eliminates the reach to get into 1st and 4th.
Much nicer / more comfortable and shorter movement to boot !
Have done a few now so can fully fit and reassemble in an hour.
Have gone for the black edition - less chrome ( suited more to 80’s metro)
Before
During
Note length difference
After
And the cherry .... had a bespoke insert made to match the original gear knob pattern / design
This was insert that came with kit
Oh, and a PS... don’t drop the gear knob while fitting , it will scratch it 🤦
#34 Maccmike8
Maccmike8
  • 1,101 posts
Posted 23 April 2021 - 07:10 PM
Very interesting and great work.
Edited by Maccmike8, 23 April 2021 - 07:12 PM.
#35 Steam
Steam
  • 748 posts
  • Local Club: Victorian Mini Club
Posted 24 April 2021 - 06:49 AM
Very nice survivor.
In the early 80s the driving school I did my test with switched from mins to metros a week before my test.
I hated them, passed the test though and could not wait to get home and drive my mini van.
#36 Ethel
  • 25,909 posts
Posted 24 April 2021 - 08:03 AM
Didn't know they did a Moke specific stick, nice idea & the extra leverage will help too.
I also reckon the ride height is ok, Mini tread ain't gonna fill the arches quite as much.
#37 longtimenomini
longtimenomini
  • 708 posts
Posted 24 April 2021 - 08:55 AM
64.1 mpg ..... yeah not how I drive !
#38 longtimenomini
longtimenomini
  • 708 posts
Posted 01 May 2021 - 05:05 PM
Well It’s taken me several days ... of walking away from the job of replacing bearing / bush in front antiroll bar.
1st bearing bush was relatively easy
second One has tested my patience - could I get all the holes to line up on brackets/ subframe .?????!!! Got one bolt in then the other wouldn’t line up , started with different bolt ... then the other wouldn’t line up !
I won the war .... but the car certainly won the battles
#39 longtimenomini
longtimenomini
  • 708 posts
Posted 01 May 2021 - 06:23 PM
So after wrestling under car for last week ... wanted an easy ( unoily) job
OE wiring was permanent live , so when I sort out stereo I will change it then.
#40 Ethel
  • 25,909 posts
Posted 02 May 2021 - 01:24 PM
Just noticed the guard around the light switch. Don't recall that on any of my Metties, has someone added it or is it a revision from the factory? Guess it's to stop you accidently switching the lights o0n when extricating yourself over those giant sills
#41 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 02 May 2021 - 05:28 PM
Good progress. Still got that clunking noise on full lock now bushes are replaced?
#42 longtimenomini
longtimenomini
  • 708 posts
Posted 02 May 2021 - 06:38 PM
Didn’t have one on my 82 vp either... maybe was a later addition ? , mine is last year of Mk1
#43 longtimenomini
longtimenomini
  • 708 posts
Posted 02 May 2021 - 06:39 PM
Think so , not been out in it , but no noise shimmying cars around driveway
#44 longtimenomini
longtimenomini
  • 708 posts
Posted 18 May 2021 - 08:45 PM
When I fitted gear lever Bobbins I wasn’t happy with the newer ones .... they were a few mm taller than old ones and much softer which translated into even more movement on gear shift particularly laterally , so bought poly ones / same height as old ones and much stiffer / tighter / dialling out looseness both in and out of gears ( stationary at least).
I’ve attempted replacing front front stabiliser bush but abandoned that for now after realising I wasn’t going to be a quick job ( are they ever?)
Once that’s fitted it be really tight gear change
#45 longtimenomini
longtimenomini
  • 708 posts
Posted 22 May 2021 - 02:48 PM
Old school .... will they work ? ...... will they fit?.... will anybody care?
Wheel saga .... now have 3 👍🏻.... one to go
Nope they are not wide enough - yet
998 HLE ... only 10 ‘on road’
NUntnAd.pngP
