Valve Seats And Machining
#16
Posted 12 April 2021 - 06:59 AM
Ac
#17
Posted 19 January 2022 - 05:28 PM
Hi all,
similar to the above i am going to purchase various HSS cutter (not doing hardened seats) for a 202 head i'm doing up to 295 spec. I'll get a 9/32" reamer as well, but i wanted to know what spindle size on the cutters i should get, I thought 7.1mm would be perfect with a touch under 0.002" clearance to keep the cutters straight, sound about right? and i take it I install the guides, then ream them, then cut seats? Thanks
7.144mm = 0.28125" (9/32")
7.1mm = 0.2795 (spindle size)
0.0017" clearance
#18
Posted 19 January 2022 - 08:38 PM
Those cheap HSS cutters are usually garbage to. Do you not have a local machine shop that can cut you a decent seat once you’ve done the rest of the work?
Phil.
#19
Posted 20 January 2022 - 09:53 AM
Thanks Phil, so maybe 0.001" clearance after reaming, ream first though? Yes i can take it somewhere but i kinda wanted to have a go myself as buying the gear would be cheaper than paying for the work to be done. But i see your point, they'd probably do a better job.
#20
Posted 20 January 2022 - 09:00 PM
It’s unlikely you’ll get any kind of decent tooling for less than that?
Phil.
