2 Speed Wiper Motor Wiring (Cable Colours?)
Best Answer Ethel , 22 March 2021 - 12:22 PM
Blue is 2 (fast).
Though it really depends on the fly leads going in to the actual motor they are:
 Red single speed
Yellow 2nd speed
Blue earth
Go to the full post
20 replies to this topic
#16 Spider
  • 14,849 posts
Posted 26 March 2021 - 07:54 PM
OK, cheers.
I have found a diagram. I'll check later today (hopefully !) and come back.
#17 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 26 March 2021 - 08:22 PM
Not great quality .. poor lighting .. but hopefully this helps
#18 Spider
  • 14,849 posts
Posted 27 March 2021 - 07:53 AM
Thanks for posting up the data sheet.
Just re-reading your last Post and if I understand that correctly, the wiring maybe;-
Terminal 1      Black / Lt Green
Terminal 2A    Red / Lt Green
Terminal 2B    Lt Green / Orange - note this also runs to the Motor as well
Terminal 3      Blue / Lt Green
All the same, could you kindly link the Switch you have.
I've had a bit of time to chew this over with a clear head.  Ethel, what do you think ?
I'm sure this will work, the worst that will happen is you'll blow a fuse.
The Motor has a Park Switch on it, and is basically a Single Pole, Double Throw switch (3 terminals). The 'Toggle' of this Park Switch is the one that should have the Black / Lt Green Wire on it. In the Parked Position, the Terminal that Makes, should be connected to Earth and the other Terminal has a +ve feed to it (from the Lt Green / Orange wire).
#19 Ethel
  • 25,922 posts
Posted 27 March 2021 - 02:01 PM
1 to the park switch (brown/light green)
2A to the low speed (red/light green)
2B ignition live feed (light green/orange)
3 to the high speed (blue/light green)
#20 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 27 March 2021 - 02:47 PM
Thanks gents ..
I was about to ask where the Light Green/Orange comes in but rechecking the wiring diagram I posted that is the Light Green at the plug .. starts LGO and changes from what I can see.
I'm "emulating" that wiring system with an ignition activated relay too so I'll just follow that wiring diagram and see where it 'leads' me ...
#21 Ethel
  • 25,922 posts
Posted 27 March 2021 - 04:54 PM
Yes,
2B will just be a live feed direct to your Durite switch to power the wipers when they're running.
