Mates,
Just got my Mini, and previous owner did some mods in an amateur way. He added the steering column drop bracket, but there's like probably 3mm or so of play where the drop bracket's bolt's sleeve is between it and the stock steering column bracket. So, basically, the whole column and steering wheel is a bit wiggly left/right, up/down. Perhaps he used the wrong bolt or wrong drop bracket...not sure. If you look at the pic, it seems like perhaps the shear bolt's nut end sheared off? Is that supposed to be like that??? And the other side there's just nothing to grab onto to remove this thing. The whole stock black bracket looks like it's attached by similar shear bolts up top so no way to remove the entire thing and cut the shear bolt off and install a normal bolt across.
First, I'm wondering why all the play. Second, how the hell do you get a shear bolt off that's had it's nut end sheared off. I'm just guessing when the previous owner installed this thing he tightened the shear bolt too much and the nut end broke off. Is that why they call it a shear bolt? What the hell is a shear bolt anyway??? Lol. Who wants bolts to shear? Jesus.
Anyway, any ideas???
Cheers!
