Strange Noise From Clutch
7 replies to this topic
#1 push
push
    Starting My Mini Up
  • 4 posts
Posted 14 March 2021 - 02:29 PM
Hi all, I have a strange whining noise from my clutch. Its there when I rev the engine and running idle. It dissapears when I hold down my clutch pedal. I have a verto clutch setup. The clutch plate had been renewed and I changed the clutch release bearing. Amy ideas?
#2 MiniMadRacer
MiniMadRacer
  • 889 posts
Posted 14 March 2021 - 02:31 PM
Did you shim the primary gear properly when replacing the clutch, and did you lube the bushes before refitting them (lightly with oil, not gallons sloshed all over it)
#3 push
push
    Starting My Mini Up
  • 4 posts
Posted 14 March 2021 - 02:36 PM
I have a video
https://youtu.be/56tdffodpuQ
#4 push
push
    Starting My Mini Up
  • 4 posts
Posted 14 March 2021 - 02:42 PM
Yes I did
#5 nicklouse
  • 18,577 posts
Posted 14 March 2021 - 02:46 PM
What is the build?
#6 push
push
    Starting My Mini Up
  • 4 posts
Posted 14 March 2021 - 02:57 PM
It is a metro engine 1293cc with evolution cam. All gearbox gears have been renewed.
#7 Spider
  • 14,840 posts
Posted 14 March 2021 - 06:11 PM
Only a guess here as I'm not familiar with the Verto Clutches.
Try backing out the bolt on the Clutch Cover that holds the Slave Cylinder Bracket and possibly the upper 2 bolts on the engine mount. It could also be one of the bolts on the timing inspection cover (but I don't think so).
It would also be worth checking the crank end float too. A check check here is with the engine running, have some one operate the clutch while you observe (closely) the Harmonic Damper, you shouldn't be able to see it move axially at all. It may even be worth checking it (engine off) with a DTI, using a Lever to push the Damper towards the Engine and the Clutch to move it back the other way.
If these check out, then I'd say there something rubbing on one of the gear teeth in either the drop gears, first motion shaft or laygear, though I'm struggling here to think of what that could be, however, if it is deemed to be in here, the engine needs to come out and at the least, the transfer housing come off. Before doing that though - and you could check this in car - with the flywheel removed, spin the primary gear and see what you can hear / feel.
#8 nicklouse
  • 18,577 posts
Posted 14 March 2021 - 09:39 PM
IIRC the Verto is a slightly odd in that the release assembly is in constant contact.
To me it sounds like the release bearing is lose and is being rattled and shuts up when the pedal is pressed.
just a thought you did refit the rubber O ring or fit a new O ring.
