Door switch
13 replies to this topic
#1 Riz_Mini
Riz_Mini
  • 127 posts
Posted 03 November 2006 - 08:35 PM
;) Right found out that my drivers side interior light swtich doesnt work..... upon investigation there isnt a wire connect to it.... how do I get to it?
Riz :w00t:
#2 the old git
the old git
  • 51 posts
  • Local Club: P&SMOC
Posted 03 November 2006 - 11:25 PM
Twist the air vent to unlock it, gently pull away the dash liner and you can get access via the hole you will see where the door stay is behind the liner. use a bit of bent copper wire to fish for it. Should be one wire with a bullet connector
#3 Riz_Mini
Riz_Mini
  • 127 posts
Posted 04 November 2006 - 09:31 AM
Thank you... will have a look for it today after my big clean `n` polish session.
Riz :D
#4 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 09:43 AM
i need to find the wire too!!! on both sides :D but can't for love nor money get the vent to untwist!!! how the hell!!!
#5 midridge2
midridge2
  • 1,794 posts
Posted 04 November 2006 - 10:25 AM
just fish for it through the hole were the switch goes.
#6 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 04 November 2006 - 10:32 AM
unscrew the outer ring then a quarter turn on the air vent should see it pop out.(if you have a dash)
#7 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 11:15 AM
I have just found (only on passenger side) two purple and white wires, i take i these are BOTH to be crimped into the bullet connector, and the the switch will earth throught the screw that holds it on?
can't see anywires on drivers side :D
#8 1984mini25
1984mini25
  • 8,783 posts
Posted 04 November 2006 - 12:39 PM
Yep thers two wires on the passenger side with one of them running along the lower dash raill to the drivers side.
#9 Riz_Mini
Riz_Mini
  • 127 posts
Posted 04 November 2006 - 03:04 PM
Cant fish the wire out..... :D any other way to get to it?
Riz
#10 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 05 November 2006 - 09:48 AM
Riz
i had to take my dash liner out
So do i use one purple and white wire per side then guys,
#11 miniboo
miniboo
  • 9,327 posts
Posted 05 November 2006 - 11:14 AM
yes one each side
#12 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 05 November 2006 - 11:18 AM
party time! excellent! party time! excellent! excellent!
#13 1984mini25
1984mini25
  • 8,783 posts
Posted 05 November 2006 - 01:18 PM
#14 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 05 November 2006 - 03:32 PM
yes but as i explained '1984, both mine had been crimped onto one.
thanks for the help guys :)
Edited by Retro_10s, 05 November 2006 - 03:32 PM.
