Auto Concepts Sw - Gsxr Bike Engine Conversion Kits
6 replies to this topic
#1 fossjw
fossjw
    Just On Tickover
  • Just Joined
  • 9 posts
Posted 04 March 2021 - 03:08 PM
I reached out via email to get more information on this kit, thought everyone here would be interested.
Looks like the new or at least based on the LynxAE kit but with a GSXR motor instead of the R1.
Facebook Link
Stage 1 Kit
Engine Cradle
Diff and associated brackets
Sprockets and Chain
Exhaust Manifold
Accusump
Reverse Mechanism
Remote Filter and Plate
Oil Cooler
Braided Oil Lines and AN-8 Fittings
Coolant Pipe
Clutch Slave Cylinder
Engine Steady and Brackets
Fuel Rail Fitting AN-6
Thermostat Housing modified
Equal Length Drive Shafts
Modified Radiator
£4,500.00
Stage 2 Kit
Bike Loom  (Required for Additional Loom for Plugs, Cam, Crank, Temperature, Rev, Coil, TPS and Injectors)
ECU and wiring loom (Cam, Crank, Temperature, Rev, Coil, TPS, Injectors and power to ECU)
Engine Mounts
Full Exhaust System Manifold back
Throttle body Trumpets and air filters
Oil Catch Tank
Radiator Fan
Coil Pack and Leads
Throttle Cable
Hardy Spicer flanges
£2,150.00
Stage 3 Kit
We install everything in Stages 1&2 for you (engines can be supplied at extra cost, please contact us for availability)
(We require the car to be at an MOT standard or if exempt to be at a driveable standard, both minus engines)
Installation cost
£1,400.00
#2 Quinlan minor
Quinlan minor
  • 1,169 posts
  • Local Club: LSMOC
Posted 04 March 2021 - 04:06 PM
I'd be very tempted at £1,400!
Sadly, I think that might be a zero short?
#3 johnR
johnR
  • 2,296 posts
Posted 06 March 2021 - 10:26 PM
I think they mean you buy the kit @ £6650 then they will fit for an extra £1400
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 06 March 2021 - 10:50 PM
And of course don't forget the most important part, the engine assy.
#5 eean
eean
  • 161 posts
Posted 10 March 2021 - 08:53 PM
Facebook Link
Stage 1 Kit
• Engine Cradle
• Diff and associated brackets
• Sprockets and Chain
• Exhaust Manifold
• Accusump
• Reverse Mechanism
• Remote Filter and Plate
• Oil Cooler
• Braided Oil Lines and AN-8 Fittings
• Coolant Pipe
• Clutch Slave Cylinder
• Engine Steady and Brackets
• Fuel Rail Fitting AN-6
• Thermostat Housing modified
• Equal Length Drive Shafts
• Modified Radiator
• £4,500.00
Stage 2 Kit
• Bike Loom  (Required for Additional Loom for Plugs, Cam, Crank, Temperature, Rev, Coil, TPS and Injectors)
• ECU and wiring loom (Cam, Crank, Temperature, Rev, Coil, TPS, Injectors and power to ECU)
• Engine Mounts
• Full Exhaust System Manifold back
• Throttle body Trumpets and air filters
• Oil Catch Tank
• Radiator Fan
• Coil Pack and Leads
• Throttle Cable
• Hardy Spicer flanges
• £2,150.00
Stage 3 Kit
Installation cost
£1,400.00
That looks superb
#6 IronmanG
IronmanG
  • 1,227 posts
  • Local Club: Box hill. Lsmoc member
Posted 12 March 2021 - 06:49 PM
That's a very neat install. What's the torque on these engines and how far up the rev range?
#7 eean
eean
  • 161 posts
Posted 13 March 2021 - 10:49 AM
Been talking to John via email on this kit, the three stages of kit including complete fitting is £8050 at the moment. So, soon as my shell is restored it's going to have it,
The R1 kit is cheaper and has lsd for 700
The reverse gearbox is included as standard, non starter motor, mechanical works off the engine, I'm more tempted with the Pro Motive kit now I've seen pictures of it
Edited by eean, 05 April 2021 - 04:50 PM.
