Mini 30Th Anniversary Engine With 7300 Miles
2 replies to this topic
#1 Paultec
Paultec
    Starting My Mini Up
  • 4 posts
Posted 28 February 2021 - 01:08 PM
Hi
In have a Mini 30th anniversary mini I’m starting to restore
The engine has 7300 on it
Is this worth anything if I decide to upgrade to 1275
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 February 2021 - 05:51 PM
They're good engines, but it's a 998, unless it can be seen running and better still, still in the car for a prospective owner able to drive then it's worth not a lot..
assming the engine number is 99HE20* then I will give you £100 for it, simply because the heads are quite good, otherwise it would be £50 for an unknown engine bare engine.
If a buyer can try before they buy then you can probably make between £400 and £600... if it's running on the floor, so you can't check the clutch/gearbox works, say £200, but needs to be sold with all it's ancillaries which makes it work. See above for bare engine.
#3 Paultec
Paultec
    Starting My Mini Up
  • 4 posts
Posted 02 March 2021 - 07:51 AM
Ok thanks for the reply
Paul
