Coolant Capacity?
5 replies to this topic
#1 DUF2
DUF2
    Formally known as DUFfi
  • 456 posts
  • Local Club: Whickham & DMC
Posted 26 February 2021 - 05:53 PM
Hi
 I have a 1275 A+ engine in my ‘65 Elf, I am flushing the cooling system but only ever seem to be able to get around 2 litres in the system. I have a drain plug fitted to the bottom of the radiator so have been draining it from there.
I thought the cooling system held 3.5 litres but can never get much more than a couple of litres in it.
Am I correct in thinking that some of the coolant is not draining out of the block?
#2 richmondclassicsnorthwales
  • 942 posts
Posted 26 February 2021 - 06:10 PM
There is coolant in the car heater matrix too.
#3 imack
imack
  • 2,103 posts
Posted 26 February 2021 - 06:28 PM
I get around 4 litres in mine although I think the Radtech radiator is a slightly higher capacity than standard.
#4 Spider
  • 14,840 posts
Posted 26 February 2021 - 06:53 PM
Yes. Draining the Radiator only, does partly drain some from the Block, but a lot will still remain in the Block. Most of the Blocks have a Drain Plug on the back of the Block, near where the Clutch Slave fits up. The late A+ didn't have a Drain here though.
#5 DUF2
DUF2
  • 456 posts
Posted 26 February 2021 - 08:56 PM
Correct, capacity without heater is 3 litres according to Haynes.
Edited by DUF2, 26 February 2021 - 08:57 PM.
#6 DUF2
DUF2
  • 456 posts
Posted 26 February 2021 - 09:02 PM
Thanks Spider, you are correct, the block on my A+ does not have a drain, the boss on the rear of the block has not been drilled.
I now realise that the water pump is above the lower water level in the block, so does not drain out all of the water.
What concerns me is, I drained the system a couple of years ago as there was not antifreeze in the system, but the block would still have contained water which could have frozen in my unheated garage!
