Best Answer Tonylamb , 27 February 2021 - 02:37 PM
So I took the dashpot off and did AC's test. Very slow and hard to push up but actually fell pretty quickly. The new damper 2085 arrived in the post this morning so I decided to experiment with the old one. I filed a little bit off the sides of the bottom part and ran a file round the top ring. Didn't make a huge difference so emptied the damper out and replaced the oil (was 20/50) with proper SU oil.
Well its a different car frankly no hesitation. pretty instant throttle response when you go back on the power from a gear change. Does feel like there is a little less power at the very top end but I suspect that is my imagination.
Oddly I'm a little dissapointed as if I couldnt fix it i was going to buy the twin HS4's. I suppose its £400 saved though. LOL
Thanks everyone in particular AC for the advice.
Go to the full post
#16
Posted 26 February 2021 - 06:23 PM
Cheers for the help.
#17
Posted 26 February 2021 - 06:43 PM
Posted 26 February 2021 - 07:03 PM
#19
Posted 26 February 2021 - 07:44 PM
Ac
#20
Posted 26 February 2021 - 09:08 PM
#21
Posted 27 February 2021 - 02:37 PM Best Answer
Mini Technical Sections →
Problems, Questions and Technical →
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
Clutch Parts And FittingStarted by Apeman85 , 10 Nov 2024 engine |
1980 998Cc Engine - Can Someone Willing To Learn Strip And Rebuild An Engine?Started by LukeClassicMan , 04 Nov 2024 engine |
Answered
Low Oil Pressure On Fresh RebuildStarted by sgallegly , 29 Oct 2024 engine |
1995 Spi Clutch Not Disengaging After ReplacementStarted by David12 , 26 Oct 2024 engine |
