Best Answer Tonylamb , 27 February 2021 - 02:37 PM
So I took the dashpot off and did AC's test. Very slow and hard to push up but actually fell pretty quickly. The new damper 2085 arrived in the post this morning so I decided to experiment with the old one. I filed a little bit off the sides of the bottom part and ran a file round the top ring. Didn't make a huge difference so emptied the damper out and replaced the oil (was 20/50) with proper SU oil.
Well its a different car frankly no hesitation. pretty instant throttle response when you go back on the power from a gear change. Does feel like there is a little less power at the very top end but I suspect that is my imagination.
Oddly I'm a little dissapointed as if I couldnt fix it i was going to buy the twin HS4's. I suppose its ÂŁ400 saved though. LOL
Thanks everyone in particular AC for the advice.
Go to the full post
Posted 25 February 2021 - 08:19 PM
One thing we noticed today is with the strobe on the timing when its at about 15 degrees of advance at idle. But when you blip the throttle instead of a steady increase in the advance it flies up to about 30 degrees settles back and then moves steadily. Is it possible a weight is loose or perhaps a spring has gone. or perhaps the weights/springs are too light? any thoughts as to if this could be the source of the flat spot.
Posted 25 February 2021 - 09:25 PM
Ac
Posted 25 February 2021 - 09:31 PM
The advance thing is odd but I didn't think it would cause the flat spot.
The carb has been vizzarded. some meat taken out of various parts to improve flow.
Any suggestions of how to sort the problem would be appreciated. The fueling in general was really good. took a bit out of the needle to richen the mid range a tiny bit.
Posted 26 February 2021 - 09:10 AM
Hi AC. I've tried different dashpot oils etc. How can I improve the drop rate of the piston? Stronger spring perhaps.
youre going to have issues setting up the carb since its been vizarded. SU carbs are finely balanced and any shaving or removing of metal will have an effect on the finely tuned things like the dashpot piston to wall clearance etc. Changing spring wont necessarily change the drop rate as its used to adjust the height:rpm. oil is there to adjust the initial jump that happens once the throttle is opened. Have a look if you can find a different damper - I know AC has made a post here about a quick drop version.
Posted 26 February 2021 - 09:27 AM
I would have thought that if only minor flowing done on carb should not create a problem if it has been properly set up for mixture and timing.
Posted 26 February 2021 - 09:43 AM
but its a case of being careful what you wish for I suppose. I think i might prefer to have less ultimate power and get rid of the flat spot.
At the moment if you are at say 4500 and you come off the throttle and go back on hard you get a mementary pause before it goes again. its irritating but not incorrect.
Graham at CCk said the flat spot was possibly caused by the flowing of the carb damper. my post was really to check if the advance on the distributor which is a bit odd could be part of the problem. i don't think so because at 4000 its pretty well advanced anyway and doesnt drop that much. As always I'm likely to go with what AC says. The issue is how to fix it. New carb perhaps. may go for twin 1.5's not as much ultimate power but possibly a better drive. or maybe another 44 which has more torque i'm told. Can I perhaps swap the damper and the pot over and see what happens?
Posted 26 February 2021 - 10:10 AM
Was the 'Vizarding' done by RetroMinis by chance?
I've never seen one personally, but have a look through the forum, where I am sure there are older posts where people have had issues with these carbs.
Posted 26 February 2021 - 11:04 AM
Posted 26 February 2021 - 12:41 PM
The question is what do I do now? I have another 44 somewhere I could swap the damper and pot and needle over and see what happens.
Posted 26 February 2021 - 03:48 PM
Posted 26 February 2021 - 05:19 PM
Ac
Posted 26 February 2021 - 06:02 PM
I dont think that I'm going to be able to get rid of this flat spot because I suspect it is caused by the carb. Not that the carb was badly done its just not I think right for the driving I'm doing.
Would you switch to twin HS4's in my position. Your opinion is of interest to me.
TW
Posted 26 February 2021 - 06:03 PM
Posted 26 February 2021 - 06:05 PM
Twins have to be in freshly rebuilt or new condition to get the best from them.
Ac
Mini Technical Sections →
Problems, Questions and Technical →
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
Clutch Parts And FittingStarted by Apeman85 , 10 Nov 2024 engine |
1980 998Cc Engine - Can Someone Willing To Learn Strip And Rebuild An Engine?Started by LukeClassicMan , 04 Nov 2024 engine |
Answered
Low Oil Pressure On Fresh RebuildStarted by sgallegly , 29 Oct 2024 engine |
1995 Spi Clutch Not Disengaging After ReplacementStarted by David12 , 26 Oct 2024 engine |
