Unusual Engine Number
7 replies to this topic
#1 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 24 February 2021 - 02:16 PM
Sorting out lots of engines which I will be selling and come across this number - DBL70-3017. Thought maybe a goldseal or similar number but not been able to find anything like it listed anywhere. It is a pre-A+ 1275 with rod change box. Looks to have been blue at some point so did think maybe a unipart exchange unit??
#2 FDW
FDW
  • Just Joined
  • 49 posts
Posted 24 February 2021 - 02:27 PM
Could be possible if there's no other explanation that someone once bought the engine with no number, so made up their own for the V5
#3 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 24 February 2021 - 02:57 PM
Seeing as there was someone else with a similar number, I doubt it's home fabricated: https://www.theminif...de-help-please/
#4 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 24 February 2021 - 04:58 PM
Has been suggested that it is a Delta rebuilt engine, have not heard of them before.
#5 Shed Racing
Shed Racing
  • 13 posts
Posted 24 February 2021 - 07:35 PM
Interestingly the DBL engine numbers have come up on MGB 1800s (I've spent the last 15 years immersed in them, although with a V8 fitted!).
In the case of the B-series engine it would seem to be DBL 230.
The DBL acronym being suggested to mean "Delco British Leyland".
The following thread shows that they haven't a real clue either!
http://www.mg-cars.n...01025175531.htm
#6 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 24 February 2021 - 09:09 PM
Seems it may well just be one of life's mysteries then!
I think I will whip the head off and see if it has been re-bored.
#7 iain1967s
iain1967s
  • 20 posts
Posted 25 February 2021 - 12:13 AM
Second photo there shows DELTA red sticker on the rocker cover.
DBL = Delta Remanufactured Engines per this:
https://mgbforum.mgb...f=3&t=494#p2202
Edited by iain1967s, 25 February 2021 - 12:14 AM.
#8 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 25 February 2021 - 12:23 AM
Oh no not another DBL engine :crazy:
I've spent hundreds of hours researching these blasted lumps without finding any logic in their numbering system or definitive proof as to why they crop up in cars occasionally....
One more thing to confuse matters even more is that your engine number should end with an E (the E denoting a rebuilt engine).
Post Script: It seems the offset stamped number isn't unusual....
http://mk1-forum.net...php?f=5&t=30782
The following information is mostly from the MG-Cars link that Shed Racing has also come across.
The DBL engines were BMC engines rebuilt at Morris Engines no2 works, Durbar avenue in Coventry alongside the RKM range of siver (short) engines & goldseal engines (this was the old Riley Factory)
They were painted a (slightly) metallic Blue & were destined to be marinised by BL recognised firms such as Calcutt and Thorneycroft -British Waterways was a big customer for theses engines but others somehow found their way into cars.
EDIT: I've since found this information is incorrect, these DBL Mini engines are nothing to do with BLMC (or Unipart).
iain1967s has found the correct answer : They were done by Delta Remanufactured Engines And Gearboxes.
Despite far too many hours researching i can't find any references to this company -so any information will be gratefully appreciated.
Edited by Itsaminithing, 26 February 2021 - 04:35 PM.
