Side Repeaters Not Working
Posted 24 February 2021 - 08:08 AM
Many thanks
Posted 24 February 2021 - 03:30 PM
Posted 24 February 2021 - 06:58 PM
If you have installed LED units make sure you have wired them with the correct polarity.
Posted 24 February 2021 - 07:57 PM
Posted 24 February 2021 - 08:58 PM
Posted 24 February 2021 - 10:28 PM
Should be very simple,
They just need an earth & the same supply that's working in the main indicator. Did you only change the repeater lenses & bulbs - same wiring?
Earth related? Shouldn't effect it, but the old style indicators can earth through the metal base, if your stumped you could take the screws out 'n see if it changes anything.
Posted 24 February 2021 - 10:48 PM
Posted 25 February 2021 - 11:37 AM
They really ought to work then. If it's not the bulbs hard to see it being anything other than an earth issue, might do it - you could have +12v going both ways in to the side flashers if you messed up the connections for the new fronts somehow & made the earth live.
Posted 25 February 2021 - 12:31 PM
Is it possible you have blown a fuse?
Posted 25 February 2021 - 02:17 PM
Repeaters aren't fused separately
Posted 25 February 2021 - 02:22 PM
I was thinking about the hazards fuse.
Posted 25 February 2021 - 04:04 PM
I seem to remember the repeater wiring comes from under the dash?If they are anything like mine the holders are full of mud and the lamps have spindly little wires and contact is tenuous.Steve..
Posted 26 February 2021 - 07:52 PM
Help!!!!
Posted 26 February 2021 - 09:00 PM
Edited by lordcakes, 26 February 2021 - 09:01 PM.
Posted 26 February 2021 - 10:41 PM
