Tip - Good Rust Remover From Screwfix (Zep Commercial)
24 replies to this topic
#1 T.Harper
T.Harper
  • 714 posts
Posted 23 February 2021 - 06:03 PM
All
Just thought I'd say that I've had good results using this relatively cheap rust remover from Screwfix.  It's a strong acid solution (Phosphoric Acid) that you dilute with 50/50 with water - have found it very effective on rusty bolts and linkages (currently rebuilding engine and carburettors).
Have only tried on steel and iron so far. Dilute versions also work, they just take longer.
Obviously be careful - wear gloves, goggles, ventilated areas, rinse well etc.
Currently £6.99 per litre which compares well compared to some of the brands targetting automotive.
https://www.screwfix...cB&gclsrc=aw.ds
#2 nicklouse
  • 18,574 posts
Posted 23 February 2021 - 10:44 PM
Should be good for cleaning out the internal waterways.
#3 Spider
  • 14,836 posts
Posted 24 February 2021 - 04:55 AM
It's good stuff and that's not a bad price either.
#4 whistler
whistler
  • 1,791 posts
Posted 24 February 2021 - 10:22 AM
I've used a few bottles over the last couple of years. Very good.
#5 panky
panky
  • 1,790 posts
Posted 24 February 2021 - 11:17 AM
I've tried it too and it works well. But I've found citric acid powder dissolved in hot water works even better and it's even cheaper.
#6 pete l
pete l
  • 1,368 posts
Posted 25 February 2021 - 01:33 PM
Surely bilt hamber DEOX would work out cheaper, you can make litres out of one bottle.
#7 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 25 February 2021 - 02:41 PM
How does that work Panky?  How much for how long?
#8 PoolGuy
PoolGuy
  • 848 posts
Posted 25 February 2021 - 02:59 PM
That’s my experience too. 10% citric acid solution, drop a block into it for 2 days, bingo.
Edited by PoolGuy, 25 February 2021 - 03:05 PM.
#9 GraemeC
GraemeC
  • 7,438 posts
Posted 25 February 2021 - 03:14 PM
I use a home made citric acid solution bath too.  Very effective and just leave things in as long as needed to do the job - I may occasionally pull them out, scrub them off then drop them back in.
One note though: these acid based de-rusting 'solutions' do leave the metal very 'bare' and as such can be very susceptible to flash rusting again quickly.  I'd recommend they are rinsed off in hot water, dried thoroughly and coated with something (paint, grease, oil, WD40) to preserve the rust free finish you've just achieved.
#10 stoneface
stoneface
  • 367 posts
Posted 25 February 2021 - 04:11 PM
A ford block I had buried in the garden for years.
Left in a bin of citric acid mix for 2 days.
Attached File  Rusty Block.jpg   67.84K   7 downloadsAttached File  Clean Block.jpg   83.19K   8 downloads
#11 panky
panky
  • 1,790 posts
Posted 25 February 2021 - 05:56 PM
The other guys have answered first but I put a cup full into a bucket of hot water and dumped all my Minor parts that would fit in to it. Took them out the next day to give them a scrub and put them back in for another 24 hours.
Rear spring/damper mounts after a wire brush but before they went in the bucket. They were very crusty
24 hrs in
and the final result
Cost about a fiver off ebay, very safe its used to make bath bombs (and sherbet  O_O )
Edited by panky, 25 February 2021 - 05:57 PM.
#12 Mini Manannán
Mini Manannán
  • 2,856 posts
Posted 25 February 2021 - 06:07 PM
24 hrs in
That's impressive results! I'm on the case...
Edited by Mini Manannán, 25 February 2021 - 06:08 PM.
#13 T.Harper
T.Harper
  • 714 posts
Posted 25 February 2021 - 09:01 PM
Good tip on the Citric too. Deox-c also looks very good.
#14 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 25 February 2021 - 10:26 PM
I've been lead to believe Deox-C is basically Citric acid.
#15 pete l
pete l
  • 1,368 posts
Posted 26 February 2021 - 08:37 AM
Bilt hamber also have a rincing product that mixes with water that prevents rusting.
https://www.bilthamb...tments/atom-mac
