downdraght carb
24 replies to this topic
#16 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 11:22 AM
lol you monkey.
#17 Brooky
Brooky
  • 104 posts
  • Local Club: Is there 1 near lancaster?????
Posted 04 November 2006 - 01:12 PM
I was down at minisport the other day and they had a manifold for a down draught nikki or webber
#18 mike998
mike998
  • 328 posts
Posted 04 November 2006 - 02:13 PM
off to the minisport website then lol.
how rare are these 997 cooper cams? so your sayin get the 1275 head with a 997 cooper cam and fit my webber?
am i gonna have to replace anything else while doing this or jus straight swap ?
#19 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 04 November 2006 - 05:53 PM
997 cam i don't think it's that rare, still available new from minisport, £38.95, it's called a 948.
Just make sure the rest of the enigne is in good nick, replace anything worn, replace oil pump because you might as well and it's only £15.
you might want to set f new cam followers they're only £15 too.
12G940 will need the block pocketing, or have the exhaust valves sunk into the head by around 40 thou maybe more.
#20 mike998
mike998
  • 328 posts
Posted 05 November 2006 - 01:39 PM
sorry im gonna sound like a dumbass but i dont know heads, never done any head work before, what is block pocketing?
cheers for the help tho you guys have been great!!
mike
#21 mike998
mike998
  • 328 posts
Posted 05 November 2006 - 01:59 PM
jus a quick thought, i found some delorto twin 40's on an alfa down the scrapy the other day, think it would be better to fit one of them to my car with the head and cam mods than if i were to waste time lookin for a downdraght manifold? then i can always sell the second delorto, or sell as a pair and have enought to buy a webber DCOE?
#22 ed4ran
ed4ran
    Cadwell Event organiser
  • 2,849 posts
Posted 05 November 2006 - 02:06 PM
lol, I dont think a highly modified 998 will make much use of a single 40
Unless its ultimate race spec!!
and youd get better MPG from a Hif.
I really think its easier to stick with a well setup SU as most will say as well,
I know people like the fact its a bit different, and that changes the sound slightly but its alot of fuel wasted and cost alot to do, just invest in your engine and use a normal SU.
When i had my Downdraught on it was on for a week or 2 until i went for a rolling road,
they didnt have the correct bits, it would have take ages to setup and it was throwing fuel into the engine, so they said stick the standard carb back on was the best way to get most power with best fuel economy.
#23 mike998
mike998
  • 328 posts
Posted 05 November 2006 - 02:08 PM
fair enough cheers for the advice.
mike
#24 Big_Adam
Big_Adam
  • 7,435 posts
Posted 05 November 2006 - 02:21 PM
mike
it's were you make a pocket for a valve in the block when using the head off a larger engined car. You either pocket the block of recess the valve into the head.
Just so you can use a head from a bigger car, that way you get bigger valves and more flow.
#25 ed4ran
ed4ran
  • 2,849 posts
Posted 05 November 2006 - 03:10 PM
Pic taken from another website that i found from searching on here for Block Pocketing.
Block pocketing topic
Edited by ed4ran, 05 November 2006 - 03:11 PM.
