Led Bulbs
18 replies to this topic
#16 FDW
FDW
  • Just Joined
  • 49 posts
Posted 12 February 2021 - 05:50 PM
Could you have fitted the bulbs the wrong way round? I have found before that this is possible even with the offset pins. This could explain your symptoms.
I'm going to have a look tomorrow, most likely looks like a bad earth or bad connection so I'll give it a shot hopefully without my fingers freezing off in the process...
#17 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 13 February 2021 - 02:42 PM
On a not-so-related note, what are the size of the festoon bulbs for the number plate lamp? Is it 36mm? I've ordered a 36mm LED festoon bulb but not exactly sure on the size.
#18 PoolGuy
PoolGuy
  • 848 posts
Posted 13 February 2021 - 04:01 PM
Update, I ordered some stop/tail lights from Classiccarleds and just fitted them. Hasn't quite gone to plan as the brake lights don't come on, they only flicker if the sidelights are on also. Anyone got some help for this?
If they're installed correctly then it sounds like an earth issue. But more info is needed on the symptoms.
#19 FDW
FDW
  • Just Joined
  • 49 posts
Posted 13 February 2021 - 05:43 PM
I think it may well be that, after removing one bulb then putting it back in the brake lights now only come on if the tail lights are on too. So I'll give the contacts in the sockets a good clean then check they're earthed properly after that tomorrow or Monday...
Edited by FDW, 13 February 2021 - 05:43 PM.
