Led Bulbs
18 replies to this topic
#1 FDW
FDW
  • Just Joined
  • 49 posts
Posted 09 February 2021 - 09:36 PM
Hi everyone, I know this is another done to death topic but I'm considering replacing all the bulbs (exterior and interior) around my Mini with LED's (Apart from headlights).
I know already that I will need new flasher units, and also that I won't change the ignition warning light, but for the rest I'm just interested in finding out what other people have got up to in terms of outcome and where they ordered them from.
I have Classiccarleds.co.uk and dynamoregulatorconversions.com already on the cards to get them from but I'm trying to make a little sense from the mess of information on previous threads about bulbs. Any input is more than welcome thanks a lot.
#2 lordcakes
lordcakes
  • 149 posts
Posted 09 February 2021 - 09:44 PM
I replaced all of external bulbs (apart from headlights) about 3 years ago and bought everything from classiccarleds. They recommend coloured leds for the indicator and brake/tail bulbs which I have and the colour under the red/orange lenses are really good, brightness is also good. No problems in the last 3 years, no failures and the only other thing I did was to replace the flasher and hazard relays for electronic ones that can cope with leds. Make sure that you clean the bulb holders up before putting your new bulbs in, otherwise it's largely plug and play.
#3 FDW
FDW
  • Just Joined
  • 49 posts
Posted 09 February 2021 - 09:48 PM
Couldn't ask for a better response so thanks for that. Forgot to mention about making sure the LEDs are coloured too as that is rather important. So 1 point to classiccarleds by the looks of it.
#4 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 09 February 2021 - 10:09 PM
I put some tail/stop LEDs in mine about 6 months ago, also from Classiccarleds, much brighter.
#5 Tds76
Tds76
  • 87 posts
Posted 09 February 2021 - 10:47 PM
Ones to avoid - I bought the Philips 1157 red stop/tail LEDs and they are hopeless in the Mk1 taillights.
The Philips LED illuminates on the side, not the end and on the Mk1 taillights this is directly into the side of the bulb holder so I only got a very faint glow through the lens.
I am sure in a more modern lamp with a reflector bowl they'd be fine.
This is the type I had, though not from this shop.
https://www.blingwor...d-brake-light-b
#6 Ol timer
Ol timer
  • 329 posts
Posted 10 February 2021 - 09:34 AM
Interested in changing mine to LEDs.is there a list anywhere as to what's required for the mini. Also the new flasher relay. Dont have hazard relay in my 1972 mini
#7 lordcakes
lordcakes
  • 149 posts
Posted 10 February 2021 - 11:38 AM
Bulb list (external)
233 or 501 front sidelight
382 front indicator
380 stop/tail
382 rear indicator, reversing, foglight
239 number plate
These numbers are referenced on the listing at classiccarleds.co.uk and are listed by type under the 12 volt section in their catalogue
They also do a flasher relay (https://www.classicc...k-x-l-p-2-3-pin). I didn't use this one and just bought a led compatible one from amazon because it was out of stock at the time but they all tend to be similar, 3 pin instead of the original 2 pin but easy to wire in, generally just needs an additional earth
Edited by lordcakes, 10 February 2021 - 11:41 AM.
#8 Cooper Mac
Cooper Mac
  • 222 posts
Posted 10 February 2021 - 05:51 PM
I had a box arrive from Classic Car LEDs yesterday!
I bought enough LEDs to convert the whole of the car, with the exception of the ignition warning light. I bought headlight and side light bulbs as well in warm white. I don't have any intention in driving at night, but as I was replacing all the rest of the bulbs, I thought I might be fully LED'd.
My car is a 1991 Cooper Carb, and I had already changed from sealed beam headlights years ago, so the sidelight bulbs may be slightly different, but listed below is what I bought:
Headlights                     H4 Pair of Warm White LED Headlights H4 Hi/Lo Beam Conversion 9-32V Excellent Beam Pattern                                                          H4ZES1WWx2
Side Light                     501 GLB501 T10 LED Warm White Capless Wedge Bulb Sidelight Number Plate Interior        12VT10WWN
Reverse Light               382 12V BA15S WHITE 21W LED 4014 SMD BULB CLASSIC / CANBUS P21W GLB382        12V382WH
Indicator Repeater       501 T10 LED ERROR FREE CANBUS 8 SMD YELLOW / AMBER W5W 501 SIDE MARKER REPEATER                                                 12VT10CANYEL20MM
Number Plate               239 WARM WHITE INTERIOR COURTESY / NUMBER PLATE LED BULB GLB239 GLB256 C5W 35 - 37 MM 12 VOLT FESTOON        12V36WW
Interior Light                 239 WARM WHITE INTERIOR COURTESY / NUMBER PLATE LED BULB GLB239 GLB256 C5W 35 - 37 MM 12 VOLT FESTOON         12V36WW
Indicator kit                   382 BRIGHT AMBER LED INDICATOR BULB KIT AND RELAY BA15S GLB382  INDKIT1 Flasher Unit - 12V 2 PIN ELECTRONIC INDICATOR FLASHER / HAZARD RELAY                                               CLASSIC CAR WITH OE CLICK 12VFL2
Stop / Tail                      380 BAY15D RED STOP / TAIL LED 1157 BRAKE REAR LIGHT GLB380 P21/5W        12VSTLRED
Gauge / Dash                501 5X GLB501 504 T10 LANDROVER DEFENDER DASHBOARD LED BULB UPGRADE VARIOUS COLOURS                                       DEF5KIT (Warm White)
Edited by Cooper Mac, 10 February 2021 - 05:57 PM.
#9 Ol timer
Ol timer
  • 329 posts
Posted 11 February 2021 - 12:33 PM
Thanks for the listing guys.
#10 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 11 February 2021 - 01:42 PM
I'm having problems with my ignition warning light (Classic Car LEDs) funnily enough after swapping, what's the issue with replacing the bulb with a LED? I did wonder if it was the LED, swapped that bulb back to original and it still doesn't work.. I wonder if I've killed something?
#11 lordcakes
lordcakes
  • 149 posts
Posted 11 February 2021 - 05:31 PM
Unlikely you have broken anything. The ignition warning (charge warning) light has 12v going to each side when the alternator is running and so the light does not illuminate, it is not just a simple case of 12v on one side and ground on the other.
For the alternator to work, the field coils inside must be energised and it gets this initial current from the flow through this charge circuit. If you replace an incandescent filament bulb with an led one there there is often not enough current to excite the coils and start the alternator off. You need to keep the original bulb or have some sort of resistor in the circuit to generate a sufficient current. Most people keep the standard bulb.
This bulb also serves to highlight if the circuit itself is at fault when you turn the ignition on. If your charge light does not illuminate when you start the car, this indicates a fault with the circuit and means that the battery is unlikely to charge once you start up. If it lights up when the car is running it indicates that the alternator voltage is less than the battery voltage so it works in 2 ways.
Edited by lordcakes, 11 February 2021 - 05:31 PM.
#12 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 12 February 2021 - 01:15 PM
Thanks, that's very helpful
#13 FlyingScot
FlyingScot
  • 2,664 posts
Posted 12 February 2021 - 01:39 PM
I wouldn’t be putting in LED headlamps as strictly speaking it should fail the MOT due to the recent changes to section 4.1.4
Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.”
FS
Link to testers guidance https://www.gov.uk/g...t#section-4-1-4
Edited by FlyingScot, 12 February 2021 - 01:42 PM.
Added link
#14 FDW
FDW
  • Just Joined
  • 49 posts
Posted 12 February 2021 - 01:40 PM
Update, I ordered some stop/tail lights from Classiccarleds and just fitted them. Hasn't quite gone to plan as the brake lights don't come on, they only flicker if the sidelights are on also. Anyone got some help for this?
#15 lordcakes
lordcakes
  • 149 posts
Posted 12 February 2021 - 05:41 PM
Could you have fitted the bulbs the wrong way round? I have found before that this is possible even with the offset pins. This could explain your symptoms.
