Clutch Pedal Bottoming, Crunchy 2Nd Gear
engine
22 replies to this topic
#16 Moshtaraq
Moshtaraq
  • 86 posts
Posted 10 February 2021 - 08:48 PM
I used that slave for 5 years without problems, what do you mean right grade? Synthetic?
#17 MiniMadRacer
MiniMadRacer
  • 884 posts
Posted 10 February 2021 - 08:53 PM
If the Slave is 5 yrs old, maybe its past its best, but as you have suggested have a look behind that rubber boot to check.
The oil is the right grade at 20 / 50 but it should be a mineral oil NOT fully synthetic, as the mini shares the engine oil with the gearbox.
The oil therefore has to be a compromise between what the engine wants and what the gear box needs.
It should be a mineral oil...a good compromise for both the engine and the gearbox
#18 Moshtaraq
Moshtaraq
  • 86 posts
Posted 10 February 2021 - 08:55 PM
Oh ok you were reffering to the oil still. Yes its mineral, also because its a new engine and the piston rings need to bed in. What do I need to see or not see behind the rubber?
#19 MiniMadRacer
MiniMadRacer
  • 884 posts
Posted 10 February 2021 - 09:50 PM
Behind the rubber you want it bone dry, no moisture or dampness
#20 Moshtaraq
Moshtaraq
  • 86 posts
Posted 10 February 2021 - 09:54 PM
Will look into that after work tomorrow thanks!
#21 Moshtaraq
Moshtaraq
  • 86 posts
Posted 11 February 2021 - 04:12 PM
I checked behind the rubber, bone dry. I can't get the arm of, the pin is stuck and I can't fit a hammer in there....
#22 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 11 February 2021 - 09:55 PM
You don't need the pin out.
What is the lockout nut clearance set at? Should be 6.5mm
#23 Moshtaraq
Moshtaraq
  • 86 posts
Posted 11 February 2021 - 10:12 PM
I changed the clearance in both ways and it didn't change a thing
