Compbrake Pedalbox Installation
30 replies to this topic
#1 Tony75
Tony75
  • 37 posts
Posted 05 February 2021 - 12:07 PM
Hello everyone
I bought this FITS MINI [CLASSIC] TOP MOUNTED HYDRAULIC PEDAL BOX KIT – DIRECT REPLACEMENT | eBay
I have searched everywhere but can't find any info from someone who has fitted this, the kit looks fantastic but comes with zero fitting instructions
So, if anyone has fitted this kit before, could you please share pictures of the installation and mounting?
Thanks in advance
Tony
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 05 February 2021 - 12:47 PM
I fail to see how that could possibly be a direct fit!
#3 sonscar
sonscar
  • 2,995 posts
Posted 05 February 2021 - 12:56 PM
Doesnt look too difficult to fit,but definately not direct bolt in.Some fabrication will be required obviously.Just think of the bragging rights when installed though.Steve..
#4 nicklouse
  • 18,579 posts
Posted 05 February 2021 - 01:09 PM
Not an easy fit. The brake parts are not in the engine bay but in the passenger area.
#5 Shooter63
Shooter63
  • 1,025 posts
Posted 05 February 2021 - 08:23 PM
I'll have a guess what they mean is that the pedal box bolts up using the existing holes for the original brake/clutch master cylinders. Should be easy enough to fit up, just make sure you fit the cylinders in the right order.
Shooter
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 05 February 2021 - 08:57 PM
Shooter
How can it do that? There’s no way that is going to fit into the opening in the crossmember inside the car.
#7 nicklouse
  • 18,579 posts
Posted 05 February 2021 - 10:19 PM
Shooter
Exactly. Not a hope in hell unless the picture is for a totally non Mini fitting product and the Mini Fitting one is actually designed for a Mini.  Or is the seller meaning MINI.
#8 Shooter63
Shooter63
  • 1,025 posts
Posted 06 February 2021 - 08:02 AM
Shooter
That's what I meant, I went on there website and all the pictures seem generic so I presumed the actual pedal box you receive will fit, but using the original mounting holes.
Shooter
#9 Tony75
Tony75
  • 37 posts
Posted 06 February 2021 - 01:59 PM
This is what I got
#10 GraemeC
GraemeC
  • 7,438 posts
Posted 06 February 2021 - 02:35 PM
So it looks like it hangs under the dash shelf, with the masters horizontal and pointing towards the driver.
#11 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 06 February 2021 - 02:46 PM
I agree, it will be difficult to add fluid to the reservoirs with a speedo binnacle in place
#12 nicklouse
  • 18,579 posts
Posted 06 February 2021 - 02:51 PM
This is what I got
Time to get the welder out and make some fittings. Or send it back.
#13 Tony75
Tony75
  • 37 posts
Posted 06 February 2021 - 03:05 PM
The braided hoses and the bracket just at the top of the picture are so you can mount the reservoirs under the bonnet, it's just the mounting of the box itself. I think I'm going to have to make some bracketry up to secure it.  I just kinda hoped that someone else on here had bought one and fitted it.  I did get an email from the supplier with photo's that a customer had sent them of it installed on theirs, but they were absolutely pointless as you couldn't see how it was mounted.
Thanks anyway guys
Tony
#14 nicklouse
  • 18,579 posts
Posted 06 February 2021 - 03:47 PM
Thanks anyway guys
Tony
Post up those pictures then. It might give us an idea.
#15 Tony75
Tony75
  • 37 posts
Posted 06 February 2021 - 05:18 PM
Have they made some bracket up that they've welded to the pedal box to mount it?
