hey there, I recently got my engine back from the builder ( yes the one I was just gonna stuff in the car and use) they set it up on a bench dyno, pretty happy 132bhp and122ib/ft on a "run in" tune.
I've now started building up the cooling, boost and clutch etc. ready for fitting into the subframe.
I've hit few problems, I've over come most but after fitting the starter motor I've noticed the distributor vacuum bowl(not sure of the name) needs to be where the starter motor is to line up the timing marks left by the engine builders.
The Vacuum bowl is at the lowest point of the distributor, I did a little googling and I see the bowl is supposed to be near the highest point on the dizzy....
I basically need to rotate the dizzy to get it to fit but this will totally screw the timing.
1 picture is a close as I can get it to the timing marks with the starter in place, is still needs to go anticlockwise about 15 degrees to line up
2nd picture this is where I'd like it to be
Can anyone help more out with some options. I'd hate to ruin the tune, it was around £400 for the dyno set up and testing.
thank you Kieran
