Car Cut Out While Driving - Now Won’T Turn Over
10 replies to this topic
#1 MarkC123
MarkC123
  • 32 posts
Posted 25 January 2021 - 09:08 PM
Hi all,
I have recently had a new engine put into my mini about a month ago. Has been driving well, did about 200 miles since - no issues on that front.
Today I started up my mini as per usual and drove for about 5 mins before I took a turn and the car died on me mid drive. I pulled in, tried starting and car and it wouldn’t turn over, didn't hear any whirring like I normally do when turning the key and wouldn't turn over at all but still have my lights etc so I checked the battery - seems good, checked fuel cut off switch, no issue. It was also under a cover so not worried about water in the dizzy.
Trying to diagnose what could cause car to stop mid driving. I’m thinking I’ve either A) blown a fuse so will check relay tomorrow or b) solenoid connection for starter is gone or has come lose?
Any tips on where to begin?
Edited by MarkC123, 25 January 2021 - 09:20 PM.
#2 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 25 January 2021 - 09:41 PM
Do you hear a click from the engine bay/dash area when you try and start it? I.E the starter motor relay firing.
#3 Tornado99
Tornado99
  • 750 posts
Posted 25 January 2021 - 09:47 PM
Could be a loose connection to ign coil or even engine earth strap. Check all electrical switches to see if anything else is not working. Pull, clean fuses and fuse box connections. When I recently distrubed my fuse box I later had several systems go off line. Full derusting all the connections at the box solved it.
Also, check the HT leads off the distributor cap. One of mine had a poorly crimped metal fitting under the boot such that the inner conductor had pull away.
#4 Tornado99
Tornado99
  • 750 posts
Posted 25 January 2021 - 09:51 PM
Oh, is this an injected car? If yes, Have you checked the inertial cut off switch in case it triggered going over a bump?
Edited by Tornado99, 25 January 2021 - 09:51 PM.
#5 sonscar
sonscar
  • 2,995 posts
Posted 25 January 2021 - 11:29 PM
Does the motor turn over if you push it in gear?Hopefully not seized.Steve..
#6 Spider
  • 14,836 posts
Posted 26 January 2021 - 02:45 AM
It could be a worn ignition switch.
#7 Dusky
Dusky
  • 5,322 posts
Posted 26 January 2021 - 07:05 AM
You’ll solve this with a test light. Find where you have power and where you don’t. If you still have 12v everywhere, get the battery tested.
#8 MarkC123
MarkC123
  • 32 posts
Posted 26 January 2021 - 09:32 AM
Hi all,
Usually when I go to start the car I’ll turn the key to the final position and I’ll hear an mechanical whirring but I don’t now and when I turn the key I get nothing.
I have checked the inertia cut off switch so it’s not that.
Has to be an electrical connection somewhere.
#9 MarkC123
MarkC123
  • 32 posts
Posted 26 January 2021 - 04:48 PM
So as an update found the issue. The wiring to the starter was in bits so soldered a new connection on and fired up no issue.
Seems like the Wiring is on the same circuit as the fuel pump hence why I didn’t hear any noises when I turned the key.
#10 Maccmike8
Maccmike8
  • 1,101 posts
Posted 26 January 2021 - 04:50 PM
Result.
#11 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 26 January 2021 - 07:12 PM
That issue would make sense as the loom starts at the starter motor
