Turbo Suzie :3
roundnose
12 replies to this topic
#1 Nossedout
Nossedout
  • 160 posts
Posted 25 January 2021 - 08:15 AM
Hello!
Approx 4 years ago I bought this 1974 Malta Built Mini. Have not had any time to open a new tread, however better late then never....
When is saw her immediately, I knew I was going to buy her and name her Suzie.
Anyway, some information:
Painted in a thick layer of Amarillo Yellow - Oil Based Paint. It had more orange peel than an orange. and literarily you could not scratch it with a screw driver and expose the bare metal.
Interior: Some tatty set of seats out of a Fiesta or Skoda and black headlining
Mechanicals: 13 Metro engine, drum brakes all round and was recently overhauled (3 years prior).
ICE: none except no parcel shelf as it had 4 massive speakers installed prior
The main objective was to get her back on the road ASAP so as to have a driving mini. up to now 2021 I still do not have a working & driving Mini.
The original plan:
Sand the whole car down to get a fresh layer of yelllow paint
Re do all mechanicals
Possibly change the 1275 metro engine to a 998
Re do seats using a set of metro or Mini
get it passed our VRT (MOT)
  • Attached File  7.jpg   42.06K   1 downloads
  • Attached File  6.jpg   66.29K   1 downloads
  • Attached File  2.jpg   51.86K   0 downloads
  • Attached File  1.jpg   41.79K   0 downloads
#2 Nossedout
Nossedout
  • 160 posts
Posted 25 January 2021 - 09:13 AM
Soon after the last photo, I ended up with  a number of clients to re do their classic car and left it on the back burner to be done.
Fast forward a year and 5 other minis purchased ( to be restored one day ) and works continued.
Plans changed:
998 Turbo engine {suck through system/draw through}
interior to be re done in full (obtained a complete interior of an MG Metro and decided to use it)
full re wiring
Paint: Ford Mondeo Imperial Blue similar to Cosworth Purple Blue with Black roof
ICE: x4 Target Components, Pioneer Headunit & JBL sub just to have some background music ;)
I did not want a show car finish but a good-looking mini to be used and abused.
#3 Nossedout
Nossedout
  • 160 posts
Posted 25 January 2021 - 09:16 AM
Changed the 998 head to a 1275 metro head. Also had several issues with my SU and found a 1inch Brand New Stromberg....
#4 nicnoo
nicnoo
  • Just Joined
  • 212 posts
  • Local Club: south warwickshire minis
Posted 25 January 2021 - 09:18 AM
Looks to be a great start point for a cracking little project.
Personally I'd keep the 1275 (as long as its in good condition) But definitely look at upgrading the front brakes.
Would make a good sleeper mini.
Good luck
#5 Nossedout
Nossedout
  • 160 posts
Posted 25 January 2021 - 09:30 AM
She was almost finished and could take it to the VRT testing station however, after a long day at work ..... I ended up putting a turbo on it.
3hours later it started.
---- This is an experiment. all pipework will be re done----- I used all bits of pipework that I had laying in the garage. ----
#6 Steve220
Steve220
  • 4,979 posts
  • Local Club: BMC
Posted 25 January 2021 - 09:46 PM
Nice concept, obviously the turbo downpipe position will be your issue.. as well as the draw through system. Fuel hitting a 60-80,000rpm blade makes me shudder!
#7 Nossedout
Nossedout
  • 160 posts
Posted 26 January 2021 - 07:56 AM
Yep still experimenting.
Yes the downpipe currently is still in the "testing phase" will be re-done at a later stage.
Draw through is a very crude system. I have read several comments both on here and on Turbominis. Obviously the blow through is more favorable as per its various advantages.
Im still testing the water ;)
#8 Nossedout
Nossedout
  • 160 posts
Posted 26 January 2021 - 07:57 AM
Good luck
brakes needs upgrading defo!
No, removed the 1275 to put a stock 998 just to blow it up with the turbo :P
#9 mini13
mini13
  • 3,809 posts
Posted 26 January 2021 - 02:14 PM
Suck through might give some "interesting" oil consumption, also that down pipe will need to be further from the clutch resovoir.
#10 nicnoo
nicnoo
  • Just Joined
  • 212 posts
Posted 26 January 2021 - 02:49 PM
3 hour turbo fit is quite impressive though.
Took me that long to fit the interior light the other week  :D
#11 Nossedout
Nossedout
  • 160 posts
Posted 29 January 2021 - 06:06 AM
I have a slight issue....
I have fitted 2 boost gauges, one on the manifold and one directly to the turbo housing (bypassed the wastegate). any one experienced low boost on suck through? i.e. 0.2 bar?
#12 mini13
mini13
  • 3,809 posts
Posted 29 January 2021 - 08:15 AM
bernoulli's law?
#13 Nossedout
Nossedout
  • 160 posts
Posted 29 January 2021 - 08:24 AM
bernoulli's law?
yes, however i would not expect to be at 0.1-02 bar boost.  the only restriction is the carb which is approx 1 icnh.
