I would recommend using a known straight edge long enough to cover all three flanges and a small set square, use the straight edge to see if they are all in line and the square for the individual flanges
Manifold Gasket ?
#16
Posted 06 January 2021 - 02:08 PM
#17
Posted 06 January 2021 - 02:12 PM
You will also see where it's not flat,I did mine still on car,just lifted up enough,so need not apply much pressure
#18
Posted 06 January 2021 - 08:03 PM
#19
Posted 06 January 2021 - 08:17 PM
Thank you 🙏
Edited by leepol83, 06 January 2021 - 08:18 PM.
#20
Posted 06 January 2021 - 08:34 PM
But again, the problem is the inlet manifold not the exhaust.
#21
Posted 06 January 2021 - 09:33 PM
Hi yes my mistake thinner inlet manifold
#22
Posted 07 January 2021 - 10:22 PM
Also if I was to put just a little gasket sealer on the gasket would this do it any harm ? https://www.ebay.co....tm/392984516181
I’ve also ordered a turbo gasket not cheap but fingers crossed, I’ve got new studs, rings, and proper mpi manifold bolts coming too from Minispares
Thanks all for the help
Edited by leepol83, 07 January 2021 - 10:37 PM.
#23
Posted 09 January 2021 - 02:51 PM
Had another play today I’ve done videos below see what you think? I’m confident it’s not right.
https://youtube.com/shorts/bELZMFcwqTw
https://youtube.com/shorts/U-m586RmXzI
https://youtu.be/cp0jbagrNYo
#24
Posted 13 January 2021 - 06:46 PM
Mine had air leak here,which the mpi matched with extra fuel,
My stainless lcb was glowing red at idle !!!,
Now all ok
#25
Posted 13 January 2021 - 06:47 PM
#26
Posted 15 January 2021 - 01:07 PM
#27
Posted 15 January 2021 - 02:49 PM
mHow you getting on with this lee?
Hi mate
Ok I’m getting there, I have the inlet manifold back and it’s been skimmed as it was bent, fingers crossed this will do it
#28
Posted 17 January 2021 - 05:23 PM
#29
Posted 17 January 2021 - 06:28 PM
Hi mateDid you fit mani mate,any good now ?
Yea got it fitted yesterday, much better and no leaks, ticks over a little low now but just need to set it up now
I.e stepper (IACV) and give it a drive to learn the ECU, but yes I’m about there 🙏 I’ve another thread with some videos it’s under 1998 mpi running issue after restoration or search my content (there’s plenty 😂🤦♂️)
Edited by leepol83, 17 January 2021 - 06:32 PM.
#30
Posted 17 January 2021 - 08:04 PM
Yes think it's needs a good run for ecu to relearn
