Manifold Gasket ?
29 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 03 January 2021 - 05:50 PM
Hi
Ive got a thread running which is getting massive so starting a fresh one so hopefully will get some more help with it 👍🏻
Currently trying to seal up my exhaust manifold on the inlet part, I’ve a 1998 mpi with an LCB manifold which I think is the issue as it was fine before I fitted that, I’ve tried a number of gaskets from genuine rover mpi ones to cheap £3.00 ones from eBay with not a lot of change, don’t get me wrong getting a little better each time, I’m looking for advice on tried and tested methods to seal it up and believe me before anyone says it I’ve searched 😂😉 this has to be a common issue as I’ve found loads of people struggling with it, but the answer is always just put a gasket on 🤷‍♂️
Would really appreciate any helpful advice and greatly appreciate all the help in my other thread aswell so thank you for that
Cheers chaps look forward to some ideas 👌🏻👍🏻
Ow and I’ve checked the depth of the flanges and the exhaust flange is a tiny bit thinner and I mean like 0.5mm if that so not a million miles off
Thanks again in advance
#2 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 03 January 2021 - 06:28 PM
Have you checked the flanges for squareness? I kept blowing manifold gaskets (all high end, swiftune, med), my lcb flanges were warped.
Decent genuine maniflow lcb and the difference was night and day
#3 leepol83
leepol83
  • 1,744 posts
Posted 03 January 2021 - 07:28 PM
Checked they look good it’s from Minispares (Maniflow) so should be good, the exhaust out isn’t leaking, it’s leaking on the inlet side, sprayed around with brake cleaner and revs up when sprayed on the inlet
Thank you
Edited by leepol83, 03 January 2021 - 07:29 PM.
#4 leepol83
leepol83
  • 1,744 posts
Posted 04 January 2021 - 06:20 PM
Anyone used these days there 1mm thick ?
https://www.ebay.co....tm/283647635349
#5 Tones61
Tones61
  • 428 posts
Posted 04 January 2021 - 07:25 PM
You will prob need a big port gasket,
I had an issue on mine where the original mpi gasket in not wide/depth enough to reach the lcb flange
#6 leepol83
leepol83
  • 1,744 posts
Posted 04 January 2021 - 07:33 PM
R right ok which gasket did you use ?
Thank you
Edited by leepol83, 04 January 2021 - 08:57 PM.
#7 Tones61
Tones61
  • 428 posts
Posted 05 January 2021 - 03:30 PM
Any big port one,I used the thick grey soft type as appossed to the foil/silver dotted one
#8 MiniMadRacer
MiniMadRacer
  • 887 posts
Posted 05 January 2021 - 04:15 PM
Are the Flanges for the Inlet Manifold and Exhaust Manifold the same thickness? I am thinking the clamping force is not sufficent across both manifolds if they are different thicknesses
#9 GraemeC
GraemeC
  • 7,438 posts
Posted 05 January 2021 - 04:25 PM
Not likely the issue if it is the inlet side leaking.  I have had a head ported so much a standard inlet manifold didn't actually cover the inlet ports though!
In fact from what's described I doubt it is the gasket at all and the thicker one linked to is unlikely to improve things.
If the exhaust manifold flanges are slightly thinner than the inlet manifold then I'd expect the inlet to seal up.  Is there anything that is prevent the inlet manifold seating properly - such as the bottom of the injection unit fouling on something that is holding it up?  Do you have port rings in place that aren't seating properly?
#10 leepol83
leepol83
  • 1,744 posts
Posted 05 January 2021 - 04:50 PM
Exactly my thought it looks like it’s pulling up nicely all even and square, I’ve got the rings in place and sealed up properly, just makes no sense
#11 leepol83
leepol83
  • 1,744 posts
Posted 05 January 2021 - 04:54 PM
Can I do a smoke test on it ?
How do you do it ?
#12 GraemeC
GraemeC
  • 7,438 posts
Posted 05 January 2021 - 05:02 PM
Are the rings allowing the manifold to tighten against the head face though - if they are too proud they'll hold it off slightly (this is where a thicker manifold might help).
I don't think a smoke test would be east to do.  I would be tempted to remove all the carb/injection stuff from the manifold and bolt it up on its own to see if I could see the issue.
But I would really check that nothing from the inlet side is sitting hard on the centre branch of the exhaust manifold.
#13 leepol83
leepol83
  • 1,744 posts
Posted 05 January 2021 - 07:38 PM
I did check the rings and they go in far enough, I did grind the rings down abit just incase but still the same, only thing I’ve noticed is on the inlet manifold faces if I put a stair edge across them it’s not flat on both of them it’s almost dished down to the hole, but does seem exactly the same in both ports and looks factory? 🤷‍♂️
#14 Tones61
Tones61
  • 428 posts
Posted 06 January 2021 - 11:37 AM
I also had to file mine flat at they were bent on the faces on inlet manifold flanges ,
Easy to do,just plug all holes with cloth
#15 leepol83
leepol83
  • 1,744 posts
Posted 06 January 2021 - 12:14 PM
Ok that makes sense bassi assuming they should be flat then ?
How did you file it what did you use ?
Thank you 🙏
On another note if I was to use a little weaker in it just to be sure would this be ok ?
https://www.ebay.co....tm/392984516181
I’ve also ordered a updated turbo gasket not cheap but hopefully good 👌🏻
Edited by leepol83, 07 January 2021 - 10:34 PM.
