Flasher Units - What's Best To Use?
14 replies to this topic
#1 MrBounce
MrBounce
  • 2,644 posts
Posted 28 December 2020 - 12:16 PM
My Midas Kit Car had the 2x "tin can" flasher units behind the dash (one for the indicators and one for the hazards), which not surprisingly fell apart when handled. I always had trouble with these things when I had my Minis - they always seemed a bit hit and miss quality-wise.
Can someone please advise on a decent reliable and more modern replacement for each of them? My knowledge of electrics is very limited so a like for like fit would be awesome.  :thumbsup:
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 28 December 2020 - 01:08 PM
Just fit a standard 3 pin relay
#3 MrBounce
MrBounce
  • 2,644 posts
Posted 28 December 2020 - 01:32 PM
Cheers - Got an example of one? :gimme: I don't know electrics at all so a "standard 3-pin relay" is like suggesting I buy "some food" for Xmas dinner. Not having a go at you - an example would be much more helpful for me. Also, the Indicator flasher has 2 pins.
Ideally I would like it to be reliable, not something that will break 6 months down the line.
Edited by MrBounce, 28 December 2020 - 01:36 PM.
#4 nicklouse
  • 18,583 posts
Posted 28 December 2020 - 01:47 PM
Agreed to me the standard was always two pin. And I am not sure what wiring changes would be needed.
I guess you are really asking is there a better relay to replace each of the ones you have there currently?
#5 MrBounce
MrBounce
  • 2,644 posts
Posted 28 December 2020 - 01:52 PM
Yes Nick - the ones I had fell apart when moved. Just looking for an easy but reliable like for like replacement for each of them.
#6 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 28 December 2020 - 01:54 PM
Sorry for the confusion.
The 3 pin relay is a simple conversion. The extra pin needs an earth and the 2 other pins are wired as the 2 pin unit.
There are different relays available, LED Non LED and flasher relays.
Edited by cal844, 28 December 2020 - 01:55 PM.
#7 richmondclassicsnorthwales
  • 942 posts
Posted 28 December 2020 - 04:12 PM
Get a Lucas SFB105 or GFU2103, But buy a good branded item - not some old *******
#8 nicklouse
  • 18,583 posts
Posted 28 December 2020 - 04:37 PM
Can be fun on a plastic tub though.
#9 PoolGuy
PoolGuy
  • 848 posts
Posted 28 December 2020 - 05:22 PM
I fitted some electronic ones when I fitted led bulbs (they work with normal bulbs too) and they’ve been reliable for the past two years and daily use. https://www.classicc...k-x-l-p-2-3-pin
#10 Spider
  • 14,849 posts
Posted 28 December 2020 - 05:52 PM
I've found these to be quite good;-
https://www.carbuild...c-flasher-relay
If you have the proper plug bases in the loom, these are just plug and play.
#11 Shooter63
Shooter63
  • 1,027 posts
Posted 28 December 2020 - 06:11 PM
I strongly advise you NOT to buy anything new with Lucas written on the box, even back in the day they were known as " The Prince of Darkness" and that was when they made stuff in the UK, something German or Japanese will probably be best
Shooter
#12 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 28 December 2020 - 06:28 PM
Make a fly lead from an earth point
#13 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 28 December 2020 - 08:16 PM
I bought a "non load" electro mechanical flasher as it can deal with normal bulbs, LED bulbs and a combination of the two.
Mine is Tridon HD13, but if you look for an "electro mechanical" flasher unit I'm sure you can find one locally e.g:
https://www.classicc...-clicking-sound
#14 MrBounce
MrBounce
  • 2,644 posts
Posted 28 December 2020 - 08:28 PM
Brilliant - some good options here - thanks everyone  :gimme:
#15 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 28 December 2020 - 09:44 PM
Let us know how you get on with the car
