Oil Drainage bolt size
Posted 01 November 2006 - 10:27 PM
It's in too tight to use an adjustable spanner and none of my others fitted.
Cheers,
Dan
Posted 01 November 2006 - 10:52 PM
Bolt size is......... hmmm, 5/16 rings a bell but don't quote me on it.
Posted 01 November 2006 - 10:56 PM
Posted 01 November 2006 - 11:01 PM
Posted 01 November 2006 - 11:57 PM
Posted 02 November 2006 - 03:21 AM
Posted 02 November 2006 - 09:17 AM
Cheers,
Posted 02 November 2006 - 09:53 AM
It shuoldn't be stripped, if it comes out, in theory it should go back in (minis don't often adhere well to theory though lol) just be careful when winding it back in. And Don't over tighten the bolt, There is a torwue setrting but i can't remember it or find it! It is one of those things you get a feel for too....
Posted 02 November 2006 - 01:24 PM
Posted 02 November 2006 - 01:41 PM
Posted 04 November 2006 - 08:50 AM
Posted 04 November 2006 - 09:44 AM
Posted 04 November 2006 - 04:00 PM
http://www.cgenterpr...ubber_metal.htm
The very first one for 14mm should compare to what I'm using. My seal is MotorMite #365269 which is a 14mm seal but I doubt it's available in Europe.
Again, 14mm shouldn't fit. The drain plug is 5/8" which is pretty darn close to 16mm. However, from first-hand experience I can say the 14mm seal from MotorMite DOES fit the Mini drain plug well.
Posted 04 November 2006 - 04:03 PM
Posted 04 November 2006 - 05:44 PM
mine's never leaked from the sump bolt, everywhere else though lol.
