Just a quick update, due to weather I’ve not been able to take the car for a spin.
I have done the drop test and it takes 3.5-4 seconds ish which is less that the SU website quotes so I tried the HIF off my other mini and it’s about the same.
I have got a yellow spring to try though which may help if the piston is lifting too quickly. The yellow is 8oz compared to the standard 4.5oz red.
Interesting both different carbs give similar drop time despite what guide states. Perhaps guide is incorrect? How does it compare to those times in the two videos I provided?
If you put a few drops of engine oil on the piston sealing area, does the drop test change significantly (it should)?
I have not heard of any fixes for poor drop test times other than replacing the dashpot and piston as a matched pair.
