Rear Window Removal And Replacement
Posted 26 December 2020 - 07:02 AM
Posted 26 December 2020 - 08:05 AM
when replacing the head lining you need to remove front and rear windows
take out the chrome strip on out side and remove the glass with the rubbers on
refit the same way, get yourself a trim tool
www.youtube.com/watch?v=lKS24ec0IyU
Edited by steeley, 26 December 2020 - 08:06 AM.
Posted 26 December 2020 - 09:12 AM
Posted 26 December 2020 - 10:07 AM
Posted 26 December 2020 - 11:36 AM
My method Is slightly different to the suggestions above.
I remove the locking strip first by gently easing the metal cover over the join off with a small screwdriver or trim tool.
Next gently pry one end of the locking strip out of the screen rubber and then pull the whole locking strip out.
Now from inside the car preferably with an assistant on the outside, give one of the top corners a thump with the side of a fist or back of your hand and it will release the glass past the rubber.ince its started, you can pull the glass free of the rubber and lift it out.
That whole process should take less than 5 mins.
If the rubber and locking strip are supple and look in good condition, there is no need to replace it. If in any doubt though, do
Refitting the glass can be a little tricky the first few times but it's not difficult.
Put the rubber into the aperture pressing it into the lip firmly all the way round making sure the join in the rubber is at the bottom directly above the boot lid handle.
Once in, you can lube the glass channel of the rubber with some car shampoo to ease the glass in easier. This is particually useful with new rubbers.
Lift the glass into place on the car by sitting the bottom of the screen into the rubber channel making sure that its central. Ease it down fully and then you can start to ease the glass in all the way round starting in the bottom corners and working up the sides and then across the top.
Use a plastic trim tool to do this either by prying the rubber gently over the edge or the glass from the outside or pushing the edge of the rubber out over the glass from the inside.
Keep working until the glass is fully seated in the rubber and the give the glass few slaps with your hand to settle it into the seal.
Next is the locking strip. Again you can lubricate the locking strip channel if you wish.
Insert the tool into the rubber at the top in the middle and then slide the locking strip into the tool. Then it's just a case if guiding the tool along the rubber channel as you push in the locking strip making sure that you are constantly forcing it tightly back especially in the corners so as to push out the rubber tightly to the body.
This is how you get a good seal. If you get this bit wrong then your screen may leak and is why lots of people use sealer on the rubber. Not something I would recommend, just fit the locking strip correctly instead.
It's quite hard to describe that step with text so might be worth having a peruse on YouTube etc for a video guide.
I would not recommend the string method though although plenty seem to have success its just not the right method for this type of rubber
Ben
Posted 26 December 2020 - 10:20 PM
The job is a complete PITA. Take it to a windscreen fitter.
Posted 27 December 2020 - 08:54 AM
Bondo yuck..... not going to be easy to get out whoever that was....
Posted 28 December 2020 - 03:44 AM
Posted 28 December 2020 - 03:59 AM
Do it yourself it isn't that hard. There are multiple Youtube videos and online guides. I use a plastic bicycle tire lever from Pedros, a Lisle 4700 fillet tool (not the cheapos that MS sells) soft rubber mallet, water soluble personal lubricant (KY or the like), and a healthy dose of patience. I've also had better luck with the Japanese sourced gasket from Classic Minis Japan (which you may be able to source in the UK)
20200518_205009.jpg 60.47K
1 downloads
Posted 24 November 2021 - 07:01 AM
Ben
Hi Ben
See in an earlier post you advocated the string method but clearly are a convert to this method; presume based on your opinion this is the easier (easier than string approach); just keen to hear.
Thanks all for your great comments. Used Ben’s approach to remove (though before I read it; just seems to be the thing to do) and will be venturing to replace this weekend
