My 1980 mini Cooper has a new gear Knob but is a bit loose. Needs a bit more rubber really. Anyone ideas about jamming it on tighter so it doesn't come off in my hand at the wrong moment?
Thanks.
Posted 25 December 2020 - 09:15 PM
Thanks.
Posted 26 December 2020 - 12:43 AM
Thanks.
Have you considered threading a nut on the gearshift lever first, then fitting the knob? Tighten the nut against the knob, basically a becoming jamnut, this is dependent on the threads inside the knob being in good shape.
Edited by croc7, 26 December 2020 - 12:45 AM.
Posted 26 December 2020 - 12:52 AM
The thread in many gear knobs is not actually a thread but just a rubber insert.
you could fill the hole with some reinforced filler material and then drill and cut a thread (or fit a threaded insert) and then use a lock nut.
Posted 26 December 2020 - 03:05 AM
Posted 26 December 2020 - 09:52 AM
Thanks all, a solution in there I'm sure.
Posted 26 December 2020 - 12:54 PM
Sikaflex inside it and screw it back on. When it sets you'll have no further issues with it coming off!
Posted 26 December 2020 - 03:48 PM
Sikaflex is incredible stuff.
Posted 27 December 2020 - 08:39 AM
Which Sikaflex? There seem to be a number of options.
Posted 27 December 2020 - 09:15 AM
EBT.
Posted 27 December 2020 - 09:22 AM
Posted 27 December 2020 - 10:23 AM
Posted 27 December 2020 - 11:42 AM
