#781
Posted 07 May 2023 - 08:32 PM
#782
Posted 08 May 2023 - 07:11 AM
#783
Posted 08 May 2023 - 04:51 PM
Thanks guys, appreciate the comments :)
Today I finished the roof repair, but unfortunately I got a bit of panel distortion. I think I didn't wait enough between welds! Anyway, nothing that a bit of filler can't fix...
I started with the repair panel. Marked it up and cut it to size.
Then I tried it in the car and grinded the edges to get a 1-2mm gap between the panels. Then I clamped it in place.
Next was to tack the panel between the clamps.
Clamps removed and continued with the welding.
Next I spot welded the repair panel along the gutters.
All grinded down...
And painted. It cannot be seen in the photos, but there's a bit of distortion in the junction of the panels. As I said earlier, I think a bit of filler should make it good.
Similar to the other side, the gutter would need to be repaired as well...
And that was it for today. I'm glad that now the roof is all done and dusted.
More coming next week.
Victor.
Edited by Viktor, 08 May 2023 - 04:51 PM.
#784
Posted 13 May 2023 - 01:31 PM
Today I started getting these two guys in.
As you can see, the old parts are not in good condition.
I started on the passenger's side, removing some of the spot welds.
New VS old...
Then I tried the panel on and realised that the inner sill should be over this panel, but it is already spot welded in place. I might need to cut the final bit, so I can put it in position.
Panel prep, black paint removed and zinc primer added on the inner face.
And that was it for today. Tomorrow I should be able to finish this side and perhaps start with the other side...
Victor.
#785
Posted 13 May 2023 - 02:29 PM
Viktor ! Do not make the same mistake as me
That panel should be fit a little higher. There an arc at the bottom, it should follow the upper edge of the floor panel.
If you leave it as on your picture the door check strap won't meet the big hole on the top.
Zpm4oLq (1).jpg 45.25K 1 downloads
#786
Posted 13 May 2023 - 06:31 PM
Hi Gaspen, good to hear from you mate. How's your Mini?
Yes, I noticed that something wasn't right. I will push it up a bit tomorrow before welding it in place.
Thanks for the advice! :)
Victor.
#787
Posted 14 May 2023 - 06:24 AM
Victor.
Thanks mate, Manuel is fine :)
Now I thinking about the next one
Pros : matching numbers and documents, 998 engine, but with 1098 crankshaft, Cooper head, big valves, twin carb
Cons : rust, rust and rust with additional terrible previous repairs
márton.jpg 39.5K 1 downloads
#788
Posted 14 May 2023 - 08:53 AM
There is a bracket that’s attached onto the closing panel that goes behind / inside the lower dash.
I’ve been through my posts but can’t find any pictures, you can buy the closer with the bracket fitted.
There is also a folded bracket under the dash to door post.
I folded my own up based on what was left of the original rusty one
#789
Posted 20 May 2023 - 06:50 PM
Thanks guys for the comments. I managed today to put the panel in the right position and weld it in place.
Panel aligned.
Then spot welded along the inner side.
And also along the outter side.
Then where I cannot reach with the spot welder I used the mig.
Then I cleaned up a bit the top welds ready for some primer.
And that was it for today. I will try to finish it tomorrow, but not sure if I would have time...
Victor.
#790
Posted 21 May 2023 - 05:15 PM
Today I managed to get the other side done.
The starting point, removing the old rusty panel.
All cleaned up and primed.
Panel prep and primed.
Then I put the panel in place and had it aligned.
Then it was time for the spot welder.
And then I used the mig welder where I couldn't reach with the spot.
All grinded down and primed.
And that was all for today.
I still need to weld the dash rail on the other side, but that will be next week.
Victor.
#791
Posted 21 May 2023 - 09:56 PM
Good to see the spot welder is getting a good workout 💪
#792
Posted 22 May 2023 - 12:15 PM
Thanks Colin. I'm getting more confident with the Mig now... It's about time after almost 3 years into this restoration! ;)
Yeah, the spot welder is great, what a brilliant buy. When doing a repair, I'm always thinking how I can use the spot welder, just to avoid grinding Mig welds!
#793
Posted 24 May 2023 - 06:34 PM
These arrived today!
I will be taking care of them over the long weekend...
Victor.
#794
Posted 24 May 2023 - 06:43 PM
#795
Posted 24 May 2023 - 07:55 PM
Hi Colin, it is indeed! For £5 I don't bother fabricating one myself!
Cheers.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 roundnose |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
