1976 Austin Mini 1000 Le Stripey
roundnose
948 replies to this topic
#61 gaspen
gaspen
  • 942 posts
Posted 01 February 2021 - 06:25 AM
I also had to make my own to fit on at the alternator mounting point.
And that way you have free access to both end of the engine block.
#62 Viktor
Viktor
  • 653 posts
Posted 01 February 2021 - 06:09 PM
I am not sure how that engine mount fit, but I made one to myself fitted to the alternator "nuts". I built up the whole engine assembly on it and it didn't collapse :) It was a good practice on welding.
I know it is far away but you shouls install these maintenance-free ball joints from Japan
Guessworks - NSR Baljoint - Set of Four BTRSC-NSR4 (guess-works.com)
Hi Gaspen, thanks for the feedback and the photo. I was thinking perhaps to start with, to put the engine on a platform trolley, get it clean and then put it on the engine stand. It seems that most people use the alternator mounting nuts to fix the engine stand plate. I will do the same, as I'm not very convinced about what I have done so far with my engine.
Thanks also for the link to the ball joints.  These are a bit pricey, but I'm sure they will be worth the money!
Cheers.
#63 Viktor
Viktor
  • 653 posts
Posted 01 February 2021 - 06:11 PM
If I remember correctly, it doesn't fit to well on the standard engine stand unless you bolt it from the clutch housing side, obviously with the housing removed.
Hi Colin, thanks. I will adapt my mounting plate to suit the alternator fixings.
Cheers.
#64 Viktor
Viktor
  • 653 posts
Indeed, good point.
Thanks guys!
#65 gaspen
gaspen
  • 942 posts
Posted 01 February 2021 - 07:05 PM
Cheers.
I bought the ball joints from Japan where they produce them - I paid "some" (lots of) VAT and duty for the import :(
Two weeks before John Guess became a distributor in the UK.
Attached File  IMG_20200923_171011.jpg   25.38K   5 downloads
#66 gaspen
gaspen
  • 942 posts
Posted 01 February 2021 - 07:26 PM
And somebody sell a Stripey on FB
https://www.facebook...073393202795123
#67 se7enmvu
se7enmvu
  • 116 posts
Posted 02 February 2021 - 11:30 AM
I imported some of these ball joints last year for my sports pack.
The bottoms were knocking within 3000 miles. The plastic that fills in where the domed seat would usually go had become detached.
They are a nice idea but unfortunately aren't worth the money. I replaced both bottoms for the original style and will swap out the tops before imm.
#68 pete l
pete l
  • 1,368 posts
Posted 02 February 2021 - 03:29 PM
Damn,
I've just ordered a set !
#69 Viktor
Viktor
  • 653 posts
Posted 03 February 2021 - 07:27 AM
Yes, I saw that and commented saying that I also have one (no response from the guy). The car is rare, but £15k is probably too much! You can get a decent MK1 for that money...
#70 Viktor
Viktor
  • 653 posts
Posted 03 February 2021 - 07:29 AM
Thanks mate. It is good to have feedback from different people, that helps a lot, especially for beginners like me!
#71 Viktor
Viktor
  • 653 posts
Posted 03 February 2021 - 07:30 AM
Damn,
Upsss, sorry about that  :shy:
#72 gaspen
gaspen
  • 942 posts
Posted 04 February 2021 - 05:13 PM
Did you installed the small spring below the ball joint ? I am not sure if it must be there but maybe helps.
#73 se7enmvu
se7enmvu
  • 116 posts
Posted 05 February 2021 - 02:44 PM
No I fitted them without the spring as this wasn't part of the kit.
#74 Viktor
Viktor
  • 653 posts
Posted 10 February 2021 - 06:00 PM
Big milestone today, as the engine is finally out of the car, YAY!
I hired the engine hoist and the guy helped me to take it out.  Very friendly lad!
I put the engine on the engine stand. At the end I went for the short end, instead of the alternator 'nuts'.  I might change that later on...
And this is my engine bay ready for a deep clean!
Thanks for watching.
Cheers.
Victor.
#75 colinf1
colinf1
  • 1,013 posts
Posted 10 February 2021 - 07:54 PM
Looks like its all good and solid, doesn't seem too be anything too nasty.
    Bing (1)
