#586
Posted 31 October 2022 - 07:28 PM
#587
Posted 05 November 2022 - 06:44 PM
Good progress today! I managed to fix the half floor in its final position, and even started welding!
I used a lot of screws to ensure the new floor panel and the car were completely flush, so the plug welds won't come out
The same at the front
Then I used every single clamp I have at hand to fix the panel to the rest of the car
And it is looking great in position. I still need to cut the section along the tunnel, but I will do that once the welding on the other 3 sides is done.
ThenI started to plug weld the front and the back, leaving the spot welding for last (tomorrow)
Nice plug welds with good penetration, although the photo is a bit dark, it can be seen...
And same at the back, with a few not so good plug welds, as I started welding in vertical, but then change to horizontal, which provides a better result.
Tomorrow I should be able to finish all the plug welds, subject to the gas bottle which is almost finished! I will also try some spot welding along the door step, which should be straightforward...
Until tomorrow then :)
Victor
#588
Posted 05 November 2022 - 08:17 PM
Just remember to clean off all the black coating on both sides of the new step so you get good spot welds.
#589
Posted 06 November 2022 - 06:01 PM
Thanks Colin, Yes I removed the black paint from the step before getting the floor in, but I gave it another go this morning before starting the spot welding.
Before that, I tried a few more plug welds, but as expected I run out of gas so couldn't finish it
Then I started spot welding the door step, taking my time between welds to avoid overheating on the spot welder. I made sure both panels were clamped properly, moving the clamps as I moved along. What an amazing bit of kit this is, and how much time you can save using it. On top of that, the finish is really nice and looks like 'factory'!
Then I started doing the internal side, following the same procedure.
And that is all done, looking smart!
And this is from the inside of the car, not all perfectly aligned, but good enough for me!
The inner sill is aligned at the front, but a bit higher to the rear. Should I cut the excess metal???
I also spot welded the floor and the heel board...
Then I removed all the screws and grinded down the plug welds. Next week I will close all the holes...
And the last thing I did today was to align the floor panel and the tunnel, using screws. This will define the line where I will cut the floor panel, making sure they are both in contact.
And from inside, the cutting line will be above the screws...
And that was all for this weekend. I guess in the next couple of weeks this half floor should be done and dusted!
Have a great week all!
Victor.
#590
Posted 06 November 2022 - 07:20 PM
I would try on a door seal to see if fully seats on the part with the excess material, if it doesn't the grind it down slightly..
I think I'm almost out of gas too, may need to change over to gasless wire for the final few bits of welding...
#591
Posted 08 November 2022 - 06:44 PM
Finished work earlier today and went to the garage for some time.
I cut the floor panel along the line with the central tunnel
Then I started preparing some copper plates to put under the panels, to ensure I'm not cuting holes when welding. These are 10cm long and have a small indent to fit between welding clamps
This is how it should work
And then I tried it on the car. The gap between panels is covered by the copper plate and it is fixed into position with the clamps
This is from inside
This is just a test fit, as I still need to clean the tunnel from paint and K-Rust before welding, but I think it would work.
I will find out this weekend!
Cheers.
Victor.
Edited by Viktor, 08 November 2022 - 06:44 PM.
#592
Posted 08 November 2022 - 09:15 PM
Clever idea with the clamps holding the copper inplace, might have to steal that one
#593
Posted 08 November 2022 - 10:50 PM
#594
Posted 09 November 2022 - 02:00 PM
Thank you both! Really appreciate the comments. I think it would also help with panel distortion, as the copper plate should hold both panels tight together. That's the theory, let's see what happens!
Victor.
#595
Posted 10 November 2022 - 10:32 AM
Should also reduce edges blowing out too much, and the weld building up a lot on the other side , interested to see how it goes
#596
Posted 10 November 2022 - 02:12 PM
I wouldn't have thought panel distortion would be much of a risk what with the big dip pressed into it right nearby, that'll give you a lot of rigidity
#597
Posted 12 November 2022 - 05:04 PM
#598
Posted 12 November 2022 - 06:33 PM
Thanks Stefan, indeed I feel a bit more confident about my welding skills. Today was a clear example of this. I did the welding along the central tunnel and the result is quite satisfactory. Some photos of the process...
First of all I cleaned the area from paint and K-Rust, leaving all clear metal on both sides.
Then I did a few more copper plates from the standard 23mm tube
Then I used the clamps and the copper plates to align and fix the panels
And finally I started welding. Overall quite satisfied about the welds, quite solid and with good penetration. The copper plates really helped to get the welding under control, and avoided cutting holes in the panels. I alternated the slots, to avoid overheating and distortion.
From left to right, I tried to overlap the previous weld with the next one to ensure full coverage and penetration.
That is all done, with the clamps removed.
Looking reasonable good from underneath
Now to weld the gaps, I fixed the copper plates with magnets.
And that is all welded now!
Also welded the rear corner
And also welded all the holes I did to fix the panel in place with screws.
I have quite a lot to grind down tomorrow. My neighbours are going to be so pleased about it! ;)
Very satisfied about today. Let's see if I can get it done tomorrow, so I can say half of the floor is all done!
Victor
Edited by Viktor, 12 November 2022 - 06:36 PM.
#599
Posted 12 November 2022 - 07:34 PM
#600
Posted 12 November 2022 - 11:25 PM
Did you get any interference when welding with the magnets that close?
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 roundnose |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
