1976 Austin Mini 1000 Le Stripey
roundnose
948 replies to this topic
#496 colinf1
colinf1
  • 994 posts
Posted 08 August 2022 - 06:33 PM
Looking good Victor, glad to see you back at it!
Hopefully you get to give your spot welder a go on the new quarter panel!
#497 Viktor
Viktor
  • 653 posts
Posted 08 August 2022 - 07:09 PM
Thanks Colin, it's good to be back. Doing all this tedious prep to get to finally use the spot welder, really looking for it!
#498 Viktor
Viktor
  • 653 posts
Posted 14 August 2022 - 06:58 PM
Didn't manage much time in the garage this weekend, mainly because it was too hot in there! At least I have completely cleaned the old wheel arch and it is now ready to receive the new one.
All cleaned up and grinded down
The middle bit is quite difficult as there is no access with the shock absorver mounting point...
After a bit of fighting, I managed to complete it all and gave a bit of K-Rust
Then I run out of time, but next week I just need to prep the new wheel arch and weld it in place. That should be more straightforward from now on.
Have a good week.
Victor.
#499 colinf1
colinf1
  • 994 posts
Posted 14 August 2022 - 08:15 PM
Yes, very hot! Full PPE does not help either!
Hopefully weather is a bit more forgiving next weekend for you!
#500 pete l
pete l
  • 1,366 posts
Posted 16 August 2022 - 09:25 AM
Please bin the K-rust, it is useless. Get some DEOX gel from bilt hamber
https://bilthamber.c...oduct/deox-gel/
#501 MacGyver
MacGyver
  • 1,027 posts
Posted 17 August 2022 - 12:19 PM
Hot? I know the feeling. 😁 31° in my garage, got lots of welding to do too but not on my mini unfortunately. 🙁
Great progress!
Ben
#502 Viktor
Viktor
  • 653 posts
Posted 24 August 2022 - 06:58 PM
Hi Pete,
Thanks for the advice. Have you had any bad experience with K-rust? Why is this product any better? Not being picky, just wanted to know the reasons for your comment.
Thanks.
Victor.
#503 pete l
pete l
  • 1,366 posts
Posted 25 August 2022 - 07:17 AM
Hi Victor,
K-Rust is supposed to be a rust CONVERTER, ie, it covers up rust and hides it for a couple of months before it comes back.
DEOX is a rust REMOVER, it dissolves away the rust.
#504 Viktor
Viktor
  • 653 posts
Posted 25 August 2022 - 07:23 PM
Hi Pete,
Thanks for the video, very educational.
Victor
#505 Viktor
Viktor
  • 653 posts
Posted 29 August 2022 - 04:50 PM
Long bank holiday weekend, and some work done in the garage. I completed the wheel arch and tried the quarter panel in. Some photos of the process:
I drilled the arch tub to get it ready for the wheel arch plug welds
And then preping the wheel arch. Lesson learnt from the other side, prepare first, then try it on. Once is in, it is a pain to take it out again!!!
New panel in place
Ready for plug welding, using this clamp to hold it in place
All welding done, with good penetration
Grinded down and painted
Then, I welded the back seat
And the rear stiffener
Then I tried the quarter panel, and it sits quite well in there, better than the other side...
So that was all for the weekend.
Next week I will put the closing panel on the wheel arch and after that I'm thninking on getting into the floors...
Have a nice week.
Victor
Edited by Viktor, 29 August 2022 - 04:51 PM.
#506 Verderad
Verderad
  • 411 posts
Posted 03 September 2022 - 08:54 PM
Lots of good progress.  Feels so good when big panels go on.
I had to make up some new tips for my spot welder, the other tips allowed the arms to touch the panels which warped the panel.
Edited by Verderad, 03 September 2022 - 08:56 PM.
#507 Viktor
Viktor
  • 653 posts
Posted 04 September 2022 - 03:36 PM
Thanks Darren. I will buy new tips, or make them for the areas that are difficult to reach.
This weekend I managed to complete the wheel arch closing panel. Some photos of the process:
First of all, prep the panel
Then, I put it in place making sure it was perfectly aligned with the boot floor underneath. Ready for welding. This time a mix of spot and plug welding
A few spot welds first...
Then plug weld the rest. I left the corner fill up for last
All grinded down
And then the small gap in the corner filled up with weld. That would be properly finished with the seam seal.
Looking good underneath
And final lick of paint
This side came together better than the other. I learned a lot form the other side and now things are going faster and better.
More updates next week
Victor
#508 colinf1
colinf1
  • 994 posts
Posted 04 September 2022 - 07:30 PM
Looking good Victor! Did you not try the longer arms to get the welds along rear bin to closing panel?
Closing panel to boot floor is seam welded along the join.
Keep up the good work!
#509 Viktor
Viktor
  • 653 posts
Posted 06 September 2022 - 06:58 PM
Hi Colin,
Thanks mate. I didn't use the longer arms, because I'm very lazy and didn't want to change them! Also as you mentioned, the pressure reduces significantly with these arms. I promise I will push myself to use the spot welder more!
Not sure which join are you referring to? Please advise on any of the colours as shown below:
Thanks again.
Victor.
#510 colinf1
colinf1
  • 994 posts
Posted 06 September 2022 - 08:43 PM
Hi Victor, see image below,
Regarding the spot welder,mine is stuck in 1.5+1.5 with 4/5 timer, control panel doesn't want to change anything. Still welds fine, but think it might be a bit too strong for some of the remaining panels. Been in contact with Vevor so will let you know know what they say/offer for a resolution.
