![Photo](https://www.theminiforum.co.uk/forums/uploads/profile/photo-thumb-128938.jpg?_r=1622823888)
#481
Posted 23 June 2022 - 07:34 PM
Post #25 should show you enough.
Worth mentioning that the front edge of that closing panel goes under the step so don't don't alarmed if it seems too long.
The top edge should fit flush with the top edge of the inner sill so make sure it is before welding.
Ben
#482
Posted 23 June 2022 - 10:07 PM
Regarding the spot welder, I think you should order some electrodes like Gilles has suggested, even with the arms angled outwards it was hard to get into places, I had to rotate the arms outwards to get to some places, but then you lose all the clamping force...
#483
Posted 25 June 2022 - 09:38 AM
https://www.theminif...rage-iow/page-2
Ben
Thanks Ben for the link, all clearly explained as always!
The only question I have left is about the inner sill. My plan was to buy the floor pans with the inner and outter sills assembled, but was going to do that later on. Now I'm not sure if I can get that closing panel in position, without having the floor pans installed first? Surely access will be more difficult once the quarter panel is in, so perhaps the sequence of works I was proposing is incorrect.
Should I get the floors in first with inner and outter sills, and then do the closing panels and quarter panels?
Posted 25 June 2022 - 09:39 AM
I'd say it would be pretty close once you drop it a fraction for the waist lines as Ben has said.
Thanks Colin, I really wanted to start welding without spending more money, but it might be better to get those electrodes...
#485
Posted 25 June 2022 - 10:27 AM
Thanks Ben for the link, all clearly explained as always!https://www.theminif...rage-iow/page-2
Ben
https://www.theminif...rage-iow/page-7
Try post #98 and #99. Shows an alternative was that might suit you better.
Cheers.
Ben
#486
Posted 25 June 2022 - 12:48 PM
Thanks Ben, that looks like a good alternative for me.
I did some work this morning and finally managed to get the wheel arch in its final position and started welding it in place.
The first plug weld is in, but I cannot continue doing the rest as my clamps are no longer enough. I ordered a couple of 450mm clamps for this and other more tricky locations
Same on the other side, just the first plug weld. I also closed the whole I did when separating the wheel arch stiffener.
I also weld the stiffener to the wheel arch, but forgot to take a photo.
As I couldn't continue welding until I receive the longer clamps, I decided to try the quarter panel again, to see if I can get it fit better.
I pushed it down to make it aligned with the boot floor, and also the waist line as advised. It sits much better now
The gap with the boot floor is now minimum, so I guess I can push the boot floor a bit up and that should do it
At the front seems to be sitting correctly
And from inside looks okay as well
The only thing that is bothering me is the lip of the wheel arch, which is not running 'parallel' to the lip of the quarter panel. Protruding more at the back and flush at the front.
Not sure if this is okay? What about the quarter panel, is it now in its correct position?
Thanks.
Victor.
Edited by Viktor, 25 June 2022 - 12:50 PM.
#487
Posted 25 June 2022 - 01:26 PM
As for the way the arch lip lines up on the tub, the only way you can tell which is the culprit is by feeling the quarter panel with your hand.
Feel it in all directions by running your hand over it and also look down it from the front and the back and look for any distortion.
If all looks good, then the arch tub needs rolling over inwards to meet the arch lip of the quarter panel.
You will want to make sure you get this bit right and definately go slow with all welding of that panel checking it with your hands as you go because any misalignment or distortion of this panel will cause you a headache during prep to correct it.
Ben
#488
Posted 26 June 2022 - 10:54 AM
Thanks Ben, I'll see what I can do. I will make sure it is properly aligned before doing any more welding.
My gut feeling is that the wheel arch is the culprit. I fought a bit with it to get into position, so that might have caused the issue. The quarter panel has been placed nicely, without pushing or forcing it into place, at it looks good when touching it and looking at it from different angles.
I will check the wheel arch again, to see where the issue might be.
Cheers.
Victor
#489
Posted 26 June 2022 - 05:35 PM
I decided to look at something else today. I ordered a few weeks back the rear valance and the closing panels, so I did it a go to see how they fit.
First I put the closing panels in, using the subframe mounts holes, but then I realized that I have already 2 layers of reinforcement under the stiffeners, so this will make it a 3rd layer, so probably not good
In any case, with the closing panels in I put the rear valance in, but everything was way off.
Then, tried it the other way around, closing panels on the rear valance first, to see if then can be fit in the car, but basically no...
Then I decided to remove the closing panels and try fit the rear valance only. This Magnum panel fits really nicely using the holes at the end of the boot floor.
With the rear valance in, I tried the closing panels but realized that the panel where the subframe mounting holes are, really needed to go. I cut the panel as per the below picture, to try it on the car, but that didn't work well. I spent 2h trying different options until I gave up. I don't have any more photos, as I was very frustrated with it...
Probably best to take a rest on this, and go back to the wheel arch and the quarter panel next time!
Victor.
#490
Posted 26 June 2022 - 08:18 PM
#491
Posted 03 July 2022 - 06:44 PM
I think I sort out the issue with the rear valance closing panels. Just bought new panels from Magnum and they fit nicely with the Magnum valance. ;)
Then I moved to the wheel arch. I bought a G-Clamp from B&Q to make sure both panels where perfectly fit before start welding. Such a nice tool for this job. Also got this new magnet lamp, perfect for welding.
Then I plug welded all the holes...
Getting good penetration, as shown below
All grinded down...
And a bit of paint to finish it off. Very solid result this time.
I still have left to weld the wheel arch to the boot floor at the rear. I was going to spot weld it, but there's not much metal in contact, so I would need to plug welded it instead.
Then I run out of time and couldn't even start it...
Hopefully more next week.
Victor
#492
Posted 05 July 2022 - 06:52 PM
I finished work early today, and managed to get into the garage to weld the wheel arch to the boot floor.
I drilled some holes in the piece
Then clamped and ready for welding
Grinded down
And this is how it looks from the top. Quite solid, with good penetration
Next time I will be welding the stiffeners into the wheel arch.
Victor
#493
Posted 09 July 2022 - 07:17 PM
Some good progress today, closing things around the wheel arch. I also used the spot welder for the first time, what a brilliant thing to have! ;)
I clamped the back seat top panel to the wheel arch to get it welded
And welded
Same with the stiffener
And then grinded down
After that I moved into the companio bin / wheel arch
And the companion bin with the rear seat. Shame I have done the holes already for plug weld. This would be ideal for the spot welder...
All grinded down as best as I could
And to finish off I did a round of paint
After that I decided to give it a go at the closing panel. First I preped the panel...
Clamped in place with all I got...
Good aligment underneath with the boot floor
And my first few spot welds. Next time I will try to align them better, but the welder is quite heavy and with the clamps is not always easy.
It is so fast and clean using the spot welder. This might speed up the project a bit...
Victor
Edited by Viktor, 09 July 2022 - 07:18 PM.
#494
Posted 09 July 2022 - 07:21 PM
#495
Posted 07 August 2022 - 06:50 PM
I have been a way for a few weeks, but now back in action. I saw people have been busy with their projects, very good progress on a few cars I have been following.
Anyway, back to the garage and worked on the LH quarter panel. Same process as the other side, a few photos...
Starting point
Panel removed
Then removed the spot welds along the B-post
A bit of wire brush to clean up the superficial rust and paint
K-rust all over the place
And zinc primer to finish off
Then I removed the wheel arch
Then I started to removed the rest of the wheel arch on the inside, which is always a pain. But this time I learned from the other side and I'm going much faster
Not bad for my retirn back!
Victor.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
