First day in the garage since the new panels arrived. I started 2 different tasks: 1) Fitting the new boot floor and closing panel. 2) Fitting a new A-Post stiffener on the passenger's side.
I will make 2 different posts for these tasks, as I have a few questions to ask.
Boot floor fits nicely in the car. I used nuts and bolts to fix it to the wheel arch stiffeners and the back lip.
![4WexYWn.jpg](https://i.imgur.com/4WexYWn.jpg)
![ediIHRe.jpg](https://i.imgur.com/ediIHRe.jpg)
![GsMj1zi.jpg](https://i.imgur.com/GsMj1zi.jpg)
I put some zinc primer in the area where the panel will be welded, but I'm still too far away from welding day...
![SAebhAB.jpg](https://i.imgur.com/SAebhAB.jpg)
I also tested the closing panel, where the rear subframe is mounted to see if it also fits.
![AmbFKJt.jpg](https://i.imgur.com/AmbFKJt.jpg)
There's a gap between the closing panel and the boot floor as seen on these photos. The panel should be aligned with the central tunnel, but there's quite a gap there
![NW1sii8.jpg](https://i.imgur.com/NW1sii8.jpg)
![wx814R5.jpg](https://i.imgur.com/wx814R5.jpg)
I noticed that the boot floor should be moved slightly up in the center of the rear seat. The green area is good enough, especially on the left. The red area is showing a big gap, which is basically what the closing panel is missing to fit it its place.
![XdlIaaE.jpg](https://i.imgur.com/XdlIaaE.jpg)
It can be seen even better on this picture:
![WrLj5Z3.jpg](https://i.imgur.com/WrLj5Z3.jpg)
Can I get some advice about how to better fit these two panels? Which is the correct sequence, or should be both panels installed at the same time? I believe I also need to put the rear subframe in place, to ensure the best aligment. Is this correct?
Many thanks in advance.
Victor.
P.S. I will do the amendments to the boot floor before welding it in place.
Edited by Viktor, 15 January 2022 - 06:51 PM.
