Good progress during Boxing day, I managed to get the boot floor repair panel in place ready for welding. Some photos of the process:
First, I removed the reinforcement plates on both sides, trying to get them in one piece so it is easy to use as a template for the new ones I will fabricate later on. I drilled the spot welds from the stiffeners, to release them from the old boot floor and reinforcement plates.
That the first one out...
Then I cleaned up the area of rusted old metal ready for the new panel to go in.
And to the other side...
A bit of masking tape on the welding areas and zinc primer underneath the stiffener.
Same on the other side...
And that is all done, ready to receive the repair panel
Repair panel aligned and ready for welding...
There's this area marked up in red, where the panel is not really adjusted. I will give it another go tomorrow before welding...
And this is how it looks from inside. The old floor where the spare wheel goes needs repairing as well. I will do that after welding the repair panel to make the area stronger.
Also the battery box edge needs a repair panel along the junction with the boot floor repair panel. Another thing to the 'to do list'
So that was it for today. Other than a bit of adjustment the repair panel is ready for welding.
I will give it a go tomorrow, hoping not to do any holes as I weld the new metal with the old floor. Fingers crossed!!!
Cheers.
Victor.
