Library Of 3D Printable Mini Releated Designs
33 replies to this topic
#1 Johnmar
Johnmar
  • 172 posts
Posted 10 December 2020 - 01:13 PM
Hi all,
More and more parts are not longer (NLA) available through the normal suppliers (mini spares, sommerfort, moss etc).
One example is the B-pillar closing plate (as requested here: https://www.theminif...-plastic-blank/
As I had this part available I measured it and redraw it in 3D so it can be downloaded an printed by everyone.
That made me wonder if there would be demand for a library of printable parts?
So in this topic I'll try to list printable parts (and other mini related stuff) designed by others or me.
Disclaimer:
The quality of these parts will depend on the quality of the design, the 3D printer, its settings and the material used and therefor the use of these parts is at your own risk
The designs listed below are all licensed under the Creative Commons - Attribution license so everyone can print them or even alter them when needed. The (printed) designs are not te be used for commercial purposes.
Request:
if you have an item that is in need of drawing up in 3D, drop me a line and lets see if we can have this drawn up in 3D
If you stumble upong a mini related printable 3D design, drop me a line this can be added to this list.
OIf you want to add your design to the library, drop me a line.
Regards,
Johnmar
3D Mini Parts and Accessories Library
Interior
iPhone Holder for Mini Cooper vehicles   https://www.thingive...m/thing:2203204
Phone Holder for Rover Mini Cooper       https://www.thingive...m/thing:3806140
Central Brake Light 25cm                        https://www.thingive...m/thing:3831938
Additional switch panel - 12V Panel V2   https://https://www....m/thing:1566847
Choke Cable Converter Ring                  https://www.thingive...m/thing:1886596
CZH628 Plug for striker B pillar               https://www.thingive...ownload:8981440
B pillar cover - pickup                              https://www.thingive...m/thing:2367181
Seat belt Bolt Cover (round cap)             https://www.thingive...m/thing:3490762
Seat belt Bolt Cover (triangle cap)          https://www.thingive...m/thing:3018522
Mini Turn Canceler (Steering wheel)       https://www.printabl...signal-canceler
Cup holder (Seat)                                   https://www.printabl...mini-cup-holder
Mini Sunvisor mounting pins.                https://www.printabl...r-mounting-pins
Window Crank Bezel                             https://www.printabl...dow-crank-bezel
Ventilation
Vent joining tube                                     https://www.thingive...m/thing:3919948
Vent Adaptors                                         https://www.thingive...m/thing:3684941
Heating tube tidy for LHD of Mini vehicle https://https://www....m/thing:3969645
Heating tube tidy for RHD of Mini vehicle  https://www.thingive...m/thing:3806201
Under Bonnet:
MPI - Airbox induction kit                         https://www.thingive...m/thing:3055334
Carb - HIF44 SU HS6 Velocity stack        https://www.thingive...m/thing:4658494
Carb - Air Filter Intake                             https://www.thingive...m/thing:2099380
Carb - Air Filter Seal                               https://www.thingive...m/thing:1976669
Windshield Washer Reservoir cap          https://www.thingive...om/thing:951750
Engine Shield Clip                                  https://www.thingive...m/thing:4627575
Exterior
Wheel center cap                                   https://www.thingive...m/thing:3042679
Wheel centre cap                                   https://www.thingive...m/thing:2525960
CZH614 - Grille Grommet                       https://www.thingive...m/thing:2526421
Whisker Clip                                           https://www.thingive...m/thing:3092620
Tools
Gearbox Double Roller Bearing Removal Spacer Tool       https://www.thingive...m/thing:3838110
Gearbox spring and ball tool for synchronizer assembly    https://www.thingive...m/thing:3838125
Wheel Bearing Installation Tool                                          https://www.thingive...m/thing:3838122
Classic Mini Oil Seal Tool                                                   https://www.thingive...ownload:8705930
Wheel Bearing Tool                                                            https://www.printabl...el-bearing-tool
Miniature Models:
Rover mini                                                 https://www.thingive...om/thing:904455
Classic Mini Christmas Ornament            https://www.thingive...m/thing:4673428
Classic mini Silhouette                             https://www.printabl...mini-silhouette
Edited by Johnmar, 18 July 2024 - 06:33 AM.
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 10 December 2020 - 01:31 PM
Heater vents JKC10025 but one piece rather than the leaky stapled together halves? Could even have some nice vanes inside to better split and diffuse the airflow?
#3 I hate Brian
I hate Brian
  • 782 posts
Posted 11 December 2020 - 06:16 PM
Brilliant johnmar
#4 IronmanG
IronmanG
  • 1,228 posts
  • Local Club: Box hill. Lsmoc member
Posted 11 December 2020 - 06:27 PM
This is a great idea
#5 Johnmar
Johnmar
  • 172 posts
Posted 11 December 2020 - 08:47 PM
Thanks guys!
#6 MacGyver
MacGyver
  • 1,027 posts
Posted 11 December 2020 - 09:00 PM
Woooooo, I think this might be a solution to a lot of stuff! 🤔
Specially as printers become better and with different materials. 😏
#7 AndrewT
AndrewT
  • 147 posts
Posted 14 December 2020 - 08:51 AM
This is great.
Can a Mod sticky this topic?
#8 MiNiKiN
MiNiKiN
  • 199 posts
Posted 14 December 2020 - 09:03 AM
Innocenti Mini "I" pedal rubber available at
https://grabcad.com/...i-mini-cooper-2
N.B. I used Liqcreate Flexible Resin to print it and found it to should be re-inforced in the rear section by adding material to the "lip" that goes over the pedal.
Did't bother to update the model, as I found NOS-rubbers
Edited by MiNiKiN, 22 February 2023 - 08:41 AM.
#9 YankeeGal
YankeeGal
    Just On Tickover
  • 8 posts
Posted 15 December 2020 - 04:34 PM
This is great!  My hubby has a wish list of prints now
#10 IronmanG
IronmanG
  • 1,228 posts
Posted 15 December 2020 - 07:21 PM
Can anyone recommend a 3d printer. Good starter models. Value for money. Differences in materials etc
#11 Johnmar
Johnmar
  • 172 posts
Posted 16 December 2020 - 05:14 AM
Hi IronmanG:
I hope you don't mind, but can you please start a seperate topic for this (and link to it to from your question here, or remove the question here in this topic) as I would like to reserve this topic for the mini 3D parts library itself. that way we can keep the information available for all, but still keep true to its topic titles.
Regard,
Johnmar
Edited by Johnmar, 05 October 2021 - 09:38 PM.
#12 carlosgt
carlosgt
  • Just Joined
  • 26 posts
Posted 20 December 2020 - 02:02 PM
good job man!
#13 Gaz66
Gaz66
  • 894 posts
Posted 13 February 2023 - 01:23 PM
A cad program for lightweight door handles would be good 👍
#14 Johnmar
Johnmar
  • 172 posts
Posted 13 February 2023 - 04:12 PM
Gaz66: drop me a line via PB and a picture of what you want and I'll (try to) draw it up for you for 3D -print. That you can also use/convert for CAD if needed..
I have seen some alloy perforated ones and I guess you want something like that..
Edited by Johnmar, 13 February 2023 - 04:12 PM.
#15 Gaz66
Gaz66
  • 894 posts
Posted 13 February 2023 - 09:36 PM
I mean exterior push button handles.
Theres some for sale on Ebay but the write up of the product leaves a lot to be desired due to strength and fitment etc.
