Dab Radio
Posted 04 December 2020 - 04:19 PM
Posted 04 December 2020 - 04:54 PM
Posted 04 December 2020 - 05:01 PM
I have a Sony Jukebox DAB unit in the house which scans as soon as you switch it on. I have a Pioneer DAB radio in the Motorhome which does the same but bought a Roberts portable DAB+ radio and it doesn't. There a DAB+ radio in our Skoda which doesn't need to scan so maybe the DAB needs to scan but the DAB+ doesn't.
Posted 04 December 2020 - 05:35 PM
I have several DAB radios in our cars (as my favourite station is Planet Rock) none of them scan on start up. The only time I had that was when the permeant live and switched live were reversed. I would double check that. The other thing that might do it, is if your signal strength is weak and it is trying to rescan to pick up better signal. Are you using a window mounted aerial as I have had limited success with those and now use a magnet mount passive Auto Leads one from Halfords for about £10.00 they are great.
Posted 04 December 2020 - 06:57 PM
Posted 04 December 2020 - 08:44 PM
The radio requires a permanent live when the key is removed to retain it memory
Posted 04 December 2020 - 09:02 PM
I have one of these Kenwood units, all wired and working correctly. Every time it is switched to DAB it shows "updating list", this is quite normal for this model and takes 5-10 seconds. As above try and find out if it's normal for your unit, otherwise it's likely the permanent live feed at fault.
Posted 04 December 2020 - 10:19 PM
A question from me regarding aerials... What's the difference between the DAB and non DAB types, is it purely signal type?
Posted 05 December 2020 - 12:05 AM
Sounds like the ignition live is connected where a permanent live feed should be. Easy to test, does the head unit switch on with the ignition switched off?
Posted 05 December 2020 - 12:06 AM
Depends. If you're wiring is good then it's the radio. If not it's the wiring. Kinda hard to tell. Did you connect the permanent live properly?
Posted 05 December 2020 - 12:07 AM
Posted 05 December 2020 - 12:08 AM
Posted 05 December 2020 - 12:12 AM
Posted 05 December 2020 - 12:15 AM
Posted 05 December 2020 - 12:48 AM
