I'm Really Struggling To Find Some Straight Info On Polishing Coach Enamel To A Mirror Shine, Can Someone Please Help!
17 replies to this topic
#16 B370PRF
B370PRF
    Starting My Mini Up
  • 1 posts
Posted 24 June 2021 - 10:26 PM
Any update on this? it looks a fantastic shine on the bonnet pic :mrcool: and like you said more coats will only give more paint depth to work with when flatting and polishing, I'm looking to use the exact same brand paint when I finish the panel work 1st.
I was originally thinking of spraying due to I'm told its less work to get flat (as long as you don't get runs!) but a roller would be far less mess and I don't mind the extra work.
hope you are still at it and haven't given up on the project as it was looking great!
#17 SolarB
SolarB
  • 1,385 posts
Posted 30 June 2021 - 01:23 PM
Brave man tackling this on a Mini with all the seams to work around.
I take my hat off to you.
#18 chuee
chuee
  • 158 posts
Posted 06 June 2022 - 01:27 AM
Done two coats so far on the full thing, it's quite tedious using a roller as runs and drips happen quite a lot,
A brush saves the drips and runs, and puts it on thicker than a paint pad. If done right, should flow to a smooth finish - just dont over-work it with the brush. Need to know how to load a brush properly, and hold it. Use the right size too. That's not hard, it's precise. Paint at room temperature - about 20C, not much above or below.
Leave to harden a couple of months before cutting, and then longer before polishing.
Wax gives it the shine you want.
