I have the engine out and replacing the clutch for good measure. Cooper SPI with a 190mm Verto Clutch
According to Haynes manual and the Rover Workshop manual it seems the clutch plate can be replaced without also having to change the pressure plate.
The pressure plate and flywheel surfaces are smooth with no obvious damage and the pressure plate seems in good condition - this would save having the recommended re balance if a new pressure plate is fitted.
In an ideal world I would change everything and get it all balanced but have to draw the line somewhere as trying to keep to a budget.
Am tempted to change just the clutch plate and release bearing as Haynes and Rover seem to say is an option.
Thoughts please ??
Edited by northernboy, 27 November 2020 - 10:56 AM.
